Canadian Events Canada, eh?
Header question
Old Aug 22, 2007 | 07:00 PM
MYRagtop's Avatar
MYRagtop
Originally Posted by eb02z06
You have to look at your car like a system-what goes in must come out. So follow the system-get more air in-pump it out and you've got good appreciable gains. Headers really shine with a cam-then they can do there job which is to scavenge the exhaust from the cam overlap-which stock cams have very lttle of.
Hey Pierre
Sounds like you need to get a good cold air intake, like a Vararam or Callaway Honker, to go along with the headers to get the sound and performance gains that you are looking for.
Lucky you are going to Carlisle, great place for deals and info. Good luck.
Old Aug 22, 2007 | 11:18 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Originally Posted by SilverSurferC6
Arun,
Everyone I have met speaks of you with great esteem for your knowledge and experience. I am a real nubie and have picked up more "disinformation" from TV shows and the wrong sources so anything you may provide will be greatly appreciated.
I do wish to mod and tune my car, but to meet my expectations. Like I said earlier, I am interested in better response. That does not need to mean sick RWHP and RWT. I am not trying to build a "Ferrari/Porsche/BMW killer" although the stock vehicle I am sure can already accomplish plenty of that.
Thank you for offering advice.
No problem Pierre, not everyone wants to set the world on fire-and believe me you get to a point and say man "why did i go this far".
For just some good boltons that will NOT affect driveabiltiy in anyway-I would get a good cold air intake-the Vortex from BPP always come to mind for me as it works very good and priced reasonably well. Basically any intake that draws fresh air outside of the engine compartment. Next an underdrive pulley-it slows down your accesorries and the drag they create on the engine-only downfall is the steering rack must be removed so it's mostly done when a cam install is taking place-they do give nice boost of around 5-10 rwhp/tq. Next is headers-the long runner headers such as the LG's do give the best torque gains-but any stainless header that is from a reputable maker will do-it's too easy to start "which is the best here" . Last would be a 160 stat-most people have this notion they will make the car burn more fuel and hurt cylinder walls from fuel wash-not true at all. The 160 stat with the proper fan settings will amke the car run around 185 degrees-that's 40 degrees cooler than stock. This goes along way to reducing heat soak in an all aluminum engine and keeping underhood temps down. With these mods only it will give you a nice boost in power-you should be around 390 rwhp-with STOCK LIKE driveability. Just look at Ian's(JASTAKARR) ride-380 + and the car still runs like stock.
I'll try to put together something that goes even further than this-some info on cams and even FI-most important thing to do is sit down and have a goal-this way you can mod carefully and buy the right parts the first time-not like me-I got carried away!
