Canadian Events Canada, eh?
Header question
Old Aug 21, 2007 | 06:07 PM
SilverSurferC6's Avatar
SilverSurferC6
Default Header question
Me again,
I will always research my upgrades significantly prior to pulling the trigger (or not). On note everyone was so helpful with advice on choice of exhaust systems.
Man, modding is like a disease!
Headers are an enigma to me. There seem to be opposing camps saying they provide a benefit while others say that the benefit is so marginal to not be worth it. While I believe that the engine may breath better, warranties may be affected and heat increased.
Obviously I am vacillating on this. Can the enlightened group offer me some further advice or commentary? Thanks everyone.
Old Aug 21, 2007 | 06:19 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Pierre, an internal combustion engine is basically a big air pump; when you make it easier to get the fresh air in and exhaust air out, the more effiecient it will be and more HP it will make. A stock engine can always gain from things like an air intake and headers/exhaust, but the gains will be relatively marginal; that being said, if you plan to mod your engine slowly over time for more and more HP, they are the best mods to make to lay the groundwork for the future. Are headers worth the expense on a stock engine? Thats a question only you can answer, it's certainly not going to hurt or hinder your engine. I would do it, because I like to squeeze every HP I can from an engine, and it also changes the tone of the exhaust in a nice way, but thats just me!
Old Aug 21, 2007 | 06:24 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Pierre, we'll talk more on the weekend but here's my Cole's Notes version.
For starters, both camps are right. If you put headers on a stock setup, the increase will be marginal....the reason being is your not letting in/processing more air. Think of your engine as a 2" pipe and you pour water through it...given the size of the opening receiving the water and the size of the opening exiting the water, your volume is, say "x". Now expand the side exiting the water to 3"...while the flow might be a bit better, you're still pouring water in at the 2" opening...getting my drift???
So unless you plan to do intake, air box, TB, and heads, the header install will generate "some" more power but the real gains will be down the road if you modify further...careful, its a slippery sloap once you get on it
Like I said, we'll talk on the weekend
Old Aug 21, 2007 | 08:09 PM
1BDRSK's Avatar
1BDRSK
Pierre, Pierre, Pierre. You've already starting modding....there is no turning back for you now! There is no trigger to pull...it's been pulled!
Seriously the best advice I can give you is to figure out 'where you want to end up' with your mods. Not having a plan will end up costing you double in the end.
Old Aug 21, 2007 | 08:17 PM
corrado's Avatar
corrado
2021 C6 of the Year Finalist - Modified
And plus they sound AMAZING!!!!!!!!!
Old Aug 21, 2007 | 08:40 PM
4GTABODT's Avatar
4GTABODT
Why am I not surprised this came from you
On the subject of mods, did our buddy Joe get his car back together?
Old Aug 21, 2007 | 09:18 PM
TorontoMark's Avatar
TorontoMark
Wish I knew where to pickup headers locally for a c5z for a good price I'd be all over them too.
Old Aug 21, 2007 | 09:45 PM
SilverSurferC6
Greg,
Getting there is half the fun. This is why I am doing as much research as I can to determine where want to be. My objective is for better throttle response ultimately while improving gas economy - sounds weird doesn't it. I really like to be able to get good range on a tank while having better response.
Old Aug 21, 2007 | 09:47 PM
SilverSurferC6
Corrado & Joe are the NOYZBOYZ!!!!
Old Aug 21, 2007 | 10:29 PM
corrado's Avatar
corrado
On the subject of mods, did our buddy Joe get his car back together?[/QUOTE]
You'll see soon enough...
Old Aug 22, 2007 | 12:52 AM
Zeeman28a's Avatar
Zeeman28a
And I looked, and I beheld a pale horse, and the name that sat on him was Death, and Hell followed with him. And SICK-VETT behind them.
Old Aug 22, 2007 | 04:52 AM
SilverSurferC6
Nice alliteration Stan.
Old Aug 22, 2007 | 07:53 AM
corrado's Avatar
corrado
I can Hear Johnny Cash right now!!!!
Old Aug 22, 2007 | 08:33 AM
kidneyboy's Avatar
kidneyboy
Originally Posted by SilverSurferC6
Greg,
From the C3 boys...fuel econonmy? What's that?
Old Aug 22, 2007 | 09:11 AM
CDN_Wolf_eh's Avatar
CDN_Wolf_eh
... it's the oposite to what you C3 guys get!
J.K. ... put the knife down Les!
Mark
Old Aug 22, 2007 | 10:09 AM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
Some for sale HERE, and he's local.
Old Aug 22, 2007 | 05:49 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Headers on a stock car are worth around 10-15 rwhp-with around the same in torque. You have to understand that these cars have a nice tuned manifold from the factory-not the "logs" of years gone by. 10-15 is quite a shock for the average cost of headers which go for around anywhere from $1000-$2000 for these cars. And don't be fooled by all the dyno tests that show "giant" 30 rwhp gains-those dyno "claims" are easily adjusted. You have to look at your car like a system-what goes in must come out. So follow the system-get more air in-pump it out and you've got good appreciable gains. Headers really shine with a cam-then they can do there job which is to scavenge the exhaust from the cam overlap-which stock cams have very lttle of. When i get a chace later today I'll put something together for everyone with C5's and C6's that will help shed some light on modding your car to save you time and money.
To Header question
Old Aug 22, 2007 | 06:11 PM
1Bad69's Avatar
1Bad69
Old Aug 22, 2007 | 06:28 PM
TorontoMark
The 1 7/8 is good for bigger cubic inch, I need the 1 3/4 for my ls6
Old Aug 22, 2007 | 06:33 PM
SilverSurferC6
Arun,
Everyone I have met speaks of you with great esteem for your knowledge and experience. I am a real nubie and have picked up more "disinformation" from TV shows and the wrong sources so anything you may provide will be greatly appreciated.
I do wish to mod and tune my car, but to meet my expectations. Like I said earlier, I am interested in better response. That does not need to mean sick RWHP and RWT. I am not trying to build a "Ferrari/Porsche/BMW killer" although the stock vehicle I am sure can already accomplish plenty of that.
Thank you for offering advice.
