Canadian Events Canada, eh?
Code reader which one ?
Old Feb 16, 2008 | 05:13 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Code reader which one ?
For my 1998 Dodge Caravan and my 2003 Pt Cruiser, there are so many out there I don't know where to begin. Which one should I get, a universal ? I want a good inexpensive one if anyone has any ideas, thanks, Wayne
Old Feb 16, 2008 | 05:17 PM
stpman's Avatar
stpman
if all you want to do is pull & rest codes a universal OBDII is fine, I have software on my PDA to do that.
Steve
Old Feb 16, 2008 | 05:56 PM
MotorHead's Avatar
MotorHead
Steve I am new at this, I am old school, any new car I have had I don't work on, I take it in. Now I want to learn how to use a code reader and diagnose problems and fix them myself, sooooo what do I need ?
Old Feb 16, 2008 | 06:07 PM
Maymyvetteliveforevr's Avatar
Wayne it's like stpman says, you can get a universal OBD 11, some come with different cartridges. The only codes you won't be able to scan is the ABS. Those scanners are big bucks.
Old Feb 16, 2008 | 06:47 PM
MotorHead's Avatar
MotorHead
So how about this one ? Also what else do I need to figure out what the codes mean or is this kit all I need ?
http://cgi.ebay.com/ebaymotors/SUPER...em250216617787
Miaugi's Avatar
Miaugi
You can check at Wallyworld for a brand called Inova, there are several models, I use a 3100C which works well and is not too expensive, also CT has them on sale quite regularly.
Old Feb 16, 2008 | 11:39 PM
NOCRISIS's Avatar
NOCRISIS
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I bought this one,it is CAN and obd11
http://www.uiftechthai.com/OBDII.htm
Old Feb 16, 2008 | 11:59 PM
MotorHead's Avatar
MotorHead
I decided to get this one from Jegs, because I am ordering a few other things there. It seems to have an added feature of giving you a general idea of whether you will pass emission testing too
http://www.jegs.com/webapp/wcs/store...0002_958651_-1
Old Feb 17, 2008 | 09:33 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Hey Wayne, I am currently looking into this myself, but I am leaning towards getting a set up that runs on my laptop. Basically you buy a ALDL to PC interface, and then some software to use with it; some of the software is freeware and some you have to buy. The hand held units don't have the flexibility that the PC versions have, and you can have much more data on the screen at once on your laptop. This is just one of several that I have found, once I started looking into this, I realized there are so many of these types of things available:
http://www.obd2allinone.com/
http://www.diydiagnostics.com/COM327_specs.htm
Here is some good info, you are going to want to get a scan tool that supports CAN-BUS protocol, not all of them do. It looks like the ELM produced units are the most popular:
http://www.alpha-bid.com/page15.html
As it turns out, ELM Electronics is Canadian, they are located in Mississauga I think:
http://www.elmelectronics.com/index.html
Old Feb 17, 2008 | 05:46 PM
MotorHead's Avatar
MotorHead
Thanks, that is what I am interested in now too. I am looking into it. Let me know if find a Canadian source for the ELM 327. Don't buy from ELM itself as it looks like they make the chip only not the device
Old Feb 17, 2008 | 10:37 PM
7t2vette's Avatar
7t2vette
I am leaning towards the ProScan Universal Scan Tool w/USB Interface for $139 at the moment, which also includes free software upgrades for life!:
http://www.myscantool.com/order.html
This also looks interesting, the PCMSCAN software from Palmer Performance Engineering, Inc; check out the screen shots and the drag strip and dyno feature:
http://www.palmerperformance.com/pro...scan/index.php
Let me know what you find out from your research so we can compare notes.
Old Feb 17, 2008 | 11:11 PM
MotorHead's Avatar
MotorHead
I am not sure I want to start spending $150 - $200 for this. I like the idea of using the laptop as I just bought one for my LM-1. I don't see much difference between these more expensive units ( aside from the software ) and the ELM 327 which is much cheaper isn't it ?
http://www.scantool.net/
I think this might be an older model but it still supports CAN
http://cgi.ebay.com/ebaymotors/ELM32...em320217717639
Old Feb 18, 2008 | 09:10 AM
7t2vette's Avatar
7t2vette
All these units basically use the ELM 327 chipset, you are correct because the only difference is the software; for some reason I am a little leary of using the freeware and I would feel more comfortable buying the software.....I guess I am thinking that if it's freeware, how good can it be?! Buying just an ELM 327 unit and using the freeware is much cheaper, you can get them for as little as $50 plus shipping. I don't know which of the bottom 2 units is newer, I think the smaller one on the right is the newer version:
There are also several units that look very similar to this one, so I suspect they are made by one source but with different labels:
To Code reader which one ?
