Canadian Events Canada, eh?
Check engine light
Old Oct 10, 2008 | 06:06 PM
z060-0's Avatar
z060-0
Default Check engine light
Stalled car trying to leave stop light in third gearCheck engine light came on right after. Shut car off, light still on. Any problem driving 02 Z06 with 30,000 km on it. Have to go to Toronto tomorrow nite for sure with it. Will I hurt it. Car runs fine.
Old Oct 10, 2008 | 06:38 PM
Bugstyvy's Avatar
Bugstyvy
I would guess no, disconnect the battery for an extended period of time, might clear it....
Old Oct 10, 2008 | 07:00 PM
speee's Avatar
speee
did you check the DIC for codes? if not i would and search online for whatever code came up.
Old Oct 10, 2008 | 07:13 PM
z060-0's Avatar
z060-0
How do I check DIC for codes?
Old Oct 10, 2008 | 07:46 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
To list your codes, turn the ignition key to the ON position, but don't start the engine. Clear any present DIC messages (like Door Ajar, or Service Steering Column) by pressing the RESET button. Then hold the OPTIONS button down, while pressing the FUEL button 4 times. This will get you into the CODES section of the DIC.
The computer will automatically display all the codes your car is or has created. It will cycle through each code every 3 seconds. You can watch it display codes for every module in your car. If you want to write them down, go ahead. Any code that ends in H is a history code - something that has occurred in the past but is fine now. The computer is very sensitive and would throw a code if you turned the radio off while tuning it.
Once the computer has finished going through all of it's automatic codes, press RESET to enter Manual Configuration. It should start with a module and show "NO CODES" or "# CODES". If it shows a number of codes, press and hold RESET until it displays "NO CODES".
2002 C5 DTC comprehensive info - LIST OF CODES IS HERE
Hope this helps.
Old Oct 10, 2008 | 08:31 PM
use2bl8's Avatar
use2bl8
Good info, Ray. Have use this several times. Now if only I can remember how to it when I need it. Maybe I should print it and leave it in the glovebox.
Old Oct 10, 2008 | 08:34 PM
VETFEVER's Avatar
VETFEVER
Originally Posted by use2bl8
Good info, Ray. Maybe I should print it and leave it in the glovebox.
That is a GREAT idea..
Old Oct 10, 2008 | 09:13 PM
z060-0's Avatar
z060-0
Hope this helps.
Did what you said. Work perfect. Came up NO CODES. Started engine. No Service light came on. Seems to have corrected itself. Could this be right?
Old Oct 11, 2008 | 05:26 AM
Cdn Z06 Mike's Avatar
Cdn Z06 Mike
Yes, could have been anything. Did you record the codes and look them up to see what it is?
Old Oct 11, 2008 | 09:29 AM
z060-0's Avatar
z060-0
Four codes came up, all with a H after them. 2283H, U1060H, 2284H, 2605H. Light did not come back on, so I guess everything is cool. Now off to the Leafs home opener.
Old Oct 12, 2008 | 09:25 AM
JUSTAKAR's Avatar
JUSTAKAR
Default stalled
All hisss tow reee...resume normal driving......note to self on dash
end of serious note....
1st or second when stopped
3rd allow much higher rpm
4th a bit of a chore and
5th take your time out of the hole.....need to ride the clutch a tad
I don't know if you can get out in 6th and still have a clutch
at the end of it all LOL.
Ian
To Check engine light
