Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Mr. Clean Stinks
Old Nov 18, 2005 | 11:43 AM
JHIRSCH's Avatar
JHIRSCH
Default Mr. Clean Stinks
I wash my car at least once a week because black is so beautifull when it's shining. I HATE the drying process (never could get the hang of it). I bought the Mr. Clean auto system and a 200MPH leaf blower. I have much more spots then if I was to drive it to dry. Automatic washes are is out of the question. Any suggestions or tips?
Old Nov 18, 2005 | 11:46 AM
70454's Avatar
70454
Change your filter.
Old Nov 18, 2005 | 11:50 AM
not08crmanymore's Avatar
not08crmanymore
Default mr clean...
Well,if you follow directions exactly like it says you shouldn't have any spots.If you deviate(leaf blower)it won't work right.I've been using it for over a year with good results.Once in a while i'll have a water spot somewhere.2 black cars i used it on and it worked fine.change filter after 10 or so washes,too.
Old Nov 18, 2005 | 11:51 AM
VET4LES's Avatar
VET4LES
I bought a leaf blower after reading on the forum how great they were. I used it for about 5 month's and I decided the only thing it is good for is blowing the water out of the Z51 rotor's and wheels. I had spots on the paint that would dry before I could finish blowing the whole car. I would then go back with a damp towel and redry. Sometime's the old way is best.
Old Nov 18, 2005 | 11:52 AM
own2vettes's Avatar
own2vettes
I've never been able to get that thing to work either. Car always has spots on it. They wipe off fairly easily but I was always under the impression that it was supposed to dry clean without any spots. I let it dry in the shade of the garage also. Nothing beats a good old hand wash and chamois.
Old Nov 18, 2005 | 11:53 AM
NVR LAT's Avatar
NVR LAT
Thanks for the info, I was thinking about buying Mr. Clean. I also do not like the leaf blower idea, tried it once and won't use it again.
Many times, if the car is only "dusty", I will fill a bucket with soapless COLD water and just give the car a "sponge bath". I'm assuming you maintain a good coat of wax on the car. It works very well. Very little water gets on the car, it therefore dries easily and quickly with terry towels or micro-fiber. An added benefit is that very little water is introduced to the brake rotors.
Old Nov 18, 2005 | 11:54 AM
mpuzach's Avatar
mpuzach
Besides making sure the filter isn't used up, you MUST use the Mr. Clean soap. Others who have tried using other liquid soaps have reported the same poor results.
I've been using it on my Machine Silver coupe with excellent results. It also worked very well on my last car which was very dark blue.
Are you doing a thorough job "painting" the entire car with the ionized water setting after washing and rinsing?
Old Nov 18, 2005 | 03:02 PM
Kelly100's Avatar
Kelly100
The mr clean system works WELL. Follow the instructions. However, you real problem is you bought black. There is no solution for that.
Old Nov 18, 2005 | 03:49 PM
Oilpatch's Avatar
Oilpatch
I bought one and used it once. The rinse phase produces a fine mist of water. In my case it was a hot day and I ended up with a million tiny water spots and had to rewash the car. I prefer to use a stream of water to rinse and dry.
Old Nov 18, 2005 | 04:12 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
I am strongly considering one of these:
http://www.crspotless.com/
Old Nov 18, 2005 | 04:15 PM
krusty's Avatar
krusty
I use Zaino car wash and a Sears 150mph electric leaf blower.Never had a water spot on my Mag Red,7 coats of Zaino may be the reason.
Old Nov 18, 2005 | 04:18 PM
gkvetteuno's Avatar
gkvetteuno
Veteran: National Guard
I have Black and there is a prerequisite, it cannot be washed if the sun is out. I wash early in the morning, late in the evening or when overcast. blow the water from taillights, grill, mirrors, emblems, marker lamps, ect and dry with soft cotton towels as quickly as possible. So far, no waterspots. It's a learning process, good luck.
Old Nov 18, 2005 | 04:21 PM
vette-oholic's Avatar
vette-oholic
If u take your time, mr clean works great.
try keeping the car wet the whole time you wash. then use the filtered water at the end and go slowly and dont miss any spots.
Old Nov 18, 2005 | 04:44 PM
PhoenixCIS's Avatar
PhoenixCIS
im with vette-oholic. thats what i do and i very rarely have spots.
Old Nov 18, 2005 | 04:47 PM
C6ULATER's Avatar
C6ULATER
Dito here as well. The leaft blower works great. Black car= wash when sun is not out or directly on the car. Another great tip is to perform a final water rinse by letting the water cascade from your hose without any type of nozzle attached to the end. The cascading water eliminates all the air pockets that are inherent with forced or accelerated water pressure. All you have on your surface are a minimal amount of larger spots of water that go bye bye once you hit them with your leaf blower. All thats left to do is dry with a microfiber towel.
Remember that this all works providing you have a good treatment of Zaino or another quality polish.
Old Nov 18, 2005 | 05:26 PM
crazyeddie's Avatar
crazyeddie
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
I wash the body with a microfiber mit, then immediately blow dry. Then I do the wheels with terry cloth towels and blow dry. Never had a water spot on my LMB. Since you invariably will get a lot of brake dust on the terry cloth towels, I just dry them then chuck em. I've been using the blower since the 80's and I believe the secret is to blow that water off fast, especially if it's sunny and warm. I have heard good things about the Mr. Clean system, not to fond of having to replace those filters--e
Old Nov 18, 2005 | 05:34 PM
dsl's Avatar
dsl
St. Jude Donor '06 / '15
I use Mr Clean too. As long as you don't let the car dry before you use the soft water rinse, then you should be ok. But if you let the car dry first, then you'll have spots.
I live in FL so it only works in the late afternoon or early morning. Once I tried it in the middle of the day, and forget it. Spots.
To Mr. Clean Stinks
Old Nov 18, 2005 | 05:41 PM
C7Z51's Avatar
C7Z51
From: Never take a girl out for a cup of coffee, the last thing you want her to be is alert and focused. Tampa, FL
St. Jude Donor '05
I'm trying a fish tank Reverse Osmosis and Deionization filter.
http://forums.corvetteforum.com/show...69&forum_id=10
Old Nov 18, 2005 | 05:46 PM
fastskyline's Avatar
fastskyline
i've been using mr clean since it came out on many different cars...as long as you change the filter and thoroughly rinse with the filtered water it will not spot even on black paint. if you have really nasty water where you live you will obviously have to change the filter more often...just like any other filter.
Old Nov 18, 2005 | 05:48 PM
DoTheyMakeOtherCars?'s Avatar
St. Jude Donor '06
Chamois
