Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Vert Top Cleaner
Old Dec 2, 2005 | 08:20 AM
dankhts's Avatar
dankhts
Default Vert Top Cleaner
Looking for something to clean/protect my black vert top. I've seen a product called the "303" kit. Has anyone had good experience with this one, or is there something better? Thanks in advance.
Old Dec 2, 2005 | 08:27 AM
Superbock's Avatar
Superbock
I second that inquiry.
Old Dec 2, 2005 | 08:34 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Hands down favorite is RaggTop cleaner and protector. Easy to use no fuss no muss.
http://www.autogeek.net/rafaca.html
Old Dec 2, 2005 | 08:35 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Originally Posted by c5BlackBeauty
Hands down favorite is RaggTop cleaner and protectorant. Easy to use no fuss no muss.
Stuff works great.
Old Dec 2, 2005 | 08:53 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
[QUOTE=c5BlackBeauty]Hands down favorite is RaggTop cleaner and protector. Easy to use no fuss no muss.
QUOTE]
You can find ragg top in several places, it's the best that I have used.
Good Luck
Old Dec 2, 2005 | 09:02 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
[QUOTE=Allzwell]
QUOTE]
Good Luck
Yup, can't beat Raggtop.
Old Dec 2, 2005 | 10:08 AM
dankhts's Avatar
dankhts
Looks like Raggtopp wins - thanks for your responses.....
Old Dec 2, 2005 | 10:42 AM
rwlc5's Avatar
rwlc5
I tried both and liked the 303 better. The Raggtop is an aerosol. It is hard to control where it sprays and I had problems with 2 different cans where it would start to foam up. A big glob of foam would then drip on the top (oak, in my case) which would then leave a dark mark. The 303 is easier to control and I did not have a foaming problem.
Old Dec 2, 2005 | 02:28 PM
MYRagtop's Avatar
MYRagtop
Used the 303 before and was quite satisfied with the results. Pretty easy to use.
Old Dec 2, 2005 | 07:06 PM
DeeGee's Avatar
DeeGee
Old Dec 2, 2005 | 07:12 PM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
But this really is no big deal because when it dries the spot disappears. BTW, I have a light oak top also. RaggTopp has worked great for me.
Old Dec 2, 2005 | 07:13 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
RaggTop is good but a bit messier to use.
Tom
Old Dec 3, 2005 | 04:49 AM
bugman's Avatar
bugman
check the pics I posted here
after 7 months, the raggtopp still makes water and dirt just roll off. I have not tried the 303 product for this, but I'm so satisfied with raggtopp I have no reason to change.
Old Dec 3, 2005 | 07:26 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
http://www.autogeek.net/303.html (303 kits in middle of page)
and
http://www.autogeek.net/rafaca.html (Raggtop kits)
both are offered with forum discount, and Raggtop is typically the forum favorite and has many repeat customers. 303 Protectant (for dash, doors, tires) is clearly the top of there game also and offers great UV protection. You could not fail with either choice.
Old Dec 3, 2005 | 09:29 AM
rws.1's Avatar
rws.1
I have used both the Aerospace 303 cleaner and protector as well as the Raggtopp products.
I prefer Raggtopp.
The advantages to Aerospace is that it is cheaper and readily avialable at most local autoparts stores... So if you want to do it now and now wait until you can order online and get delivery fo rnext weekend's project.....
you can use Aerospace with the confidence that it will do the job just fine.
Old Dec 3, 2005 | 11:57 AM
agentf1's Avatar
agentf1
St. Jude Donor '10
303 or Raggtop. The only disavantage I see with 303 is you can only buy it in a kit and everybody seems to use the protectant alot more than the cleaner so you end up with multiple bottles of the cleaner. I can attest the 303 works awesome on cloth tops.
To Vert Top Cleaner
