Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
PC setting - ???
Old May 10, 2006 | 08:50 AM
Joe C's Avatar
Joe C
Default PC setting - ???
i've been using my PC at the 3.5 setting, and it seems to take forever for results . i'm using meguirers yellow pad with fine cut cleaner to remove swirls. i see some of the forum members are using an orange pad with settings at 5 to 6. questions: is my PC setting too low or slow? should i be using a more agressive pad and or more agressive cleaner/polish? comments, comments, comments... TIA
Old May 10, 2006 | 09:46 AM
ssj4's Avatar
ssj4
5.5 with Z Fusion and orange pad got me great results on black paint, if I would go over the car again with a white pad, it might be perfect (except for the 12 years of chips).
Old May 10, 2006 | 11:58 AM
agentf1's Avatar
agentf1
St. Jude Donor '10
Bump it up to 5.5 or 6 for your SSR's and keep it at 3.5 for applying any LSP's like wax.
Old May 10, 2006 | 12:15 PM
Joe C's Avatar
Joe C
"OK" - went brain dead here - ??? - SSR's, LSP's - ???
Old May 10, 2006 | 01:16 PM
ZaneO's Avatar
ZaneO
SSR = swirl scratch remover
LSP = last step product/protectant
Old May 10, 2006 | 02:04 PM
agentf1's Avatar
agentf1
St. Jude Donor '10
Sorry, Zane is correct. I assume everybody is a detail junkie like me. And get lazy typing.
Old May 10, 2006 | 07:06 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
Although I would personally add the wax/sealant of your choice by hand as possible as well as remove. You will waste to much product while applying and most wax/sealants are darn easy to remove these days.
Old May 11, 2006 | 06:45 AM
Joe C's Avatar
Joe C
thanks for the replies. i bumped the setting to 5.5 and things went much better. any suggestions on removing micro-marring
Old May 11, 2006 | 11:40 AM
ZaneO's Avatar
ZaneO
Make sure you are working the polish fully and switch to a finer pad and/or polish combination.
To PC setting - ???
