Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Tarrrr!
Old Jun 9, 2006 | 08:18 PM
2008 Atomic Orange's Avatar
2008 Atomic Orange
Default Tarrrr!
Curious---What do you use to take tar off? I use WD40(small amount on a rag) then wash off the area and wax.
Old Jun 9, 2006 | 08:23 PM
aminnich's Avatar
aminnich
Or kerosene, brake clean, etc. Then rewash and rewax. Best to avoid road tar all together, but when I can't it is about the only thing nice about the black sheep when it comes to keeping the outside clean.
Old Jun 9, 2006 | 08:36 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
I use Claybar followed with 3M finishing glaze. Then polish and seal.
Old Jun 9, 2006 | 10:30 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
jsup, you still with us? Glad to see you, man!!!
Answer: you can try all of those. I spoke with an install guy for clear bra. His take is most of that stuff is not great for the paint (or his clear bra).
He uses a clay bar and finish fluid. Says it's the best for the paint. Seeing as how I've got a "light" colored car just like yours (and that's the reason I called and asked him), I'll take his advice.
One other thing I learned from another person: when you get the clay bar, cut it into little one (or so) inch squares. If you drop the clay bar, because it's like a magnet to dirt and sand, you're not supposed to reuse it. This means, you throw it away. Better to throw away a one inch square of this 10 dollar stuff, than the whole bar!
I'm gonna try it.
Old Jun 10, 2006 | 01:44 AM
pmoon's Avatar
pmoon
Default Tar...
Go to your local supermarket and buy a 98 cent bottle of lamp oil. Cheap and effective.
Old Jun 10, 2006 | 03:03 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Default Tarr!!
I like paint thinner. Cheap, already on hand, works quick, and no oily residue. A wax touch-up is recommended.
Seems to me that clay-bar is too expensive to foul up by contaminating it with tar. It can't be much good if it's got tar in it!
Old Jun 10, 2006 | 08:14 AM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Stoners Tarminator
Old Jun 10, 2006 | 12:29 PM
rightofway's Avatar
rightofway
i would advise against paint thinner as it actually weakens the paint everytime you apply it
on my bike i use bug and tar remover (white can with some orange and blue on it) to get all the bugs and tar off it is nice cause my chain slings wax everywhere
Old Jun 11, 2006 | 02:03 AM
93RubyZ's Avatar
93RubyZ
Try Simple Green. It seemed to work better than bug and tar remover.
Old Jun 11, 2006 | 09:32 AM
rubyred93's Avatar
rubyred93
3M Adhesive Remover....works very well.
Old Jun 11, 2006 | 10:45 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
PB blaster, also great for removing rubber from rear quarters.
Old Jun 11, 2006 | 03:29 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
I really like Poorboys Bug Squash, full strength. You can also mix it while washing your car for a little extra umph .... helps with dirt, bugs, tar and roadkill (JOKE).
http://www.autogeek.net/poorboys-bug-squash.html
Old Jun 14, 2006 | 09:21 PM
2008 Atomic Orange
Sorry about the delay--computer problems--Thanks for the response
Old Jun 15, 2006 | 12:31 AM
bugman's Avatar
bugman
paint thinner - dirt cheap, widely available. Great for chain grease, tar, you name it---
have used it on motorcycles and cars for 15 years. never a problem on paint that is fully cured.
Old Jun 15, 2006 | 06:51 AM
Sleper's Avatar
Sleper
Paint thinner
Old Jun 15, 2006 | 10:37 AM
rstackjd's Avatar
rstackjd
I Haven't tried it on tar yet but Goo Gone seems to remove most anything. Got all the old adhesive off my interior when I removed the cheap-azz woodgrain crap.
To Tarrrr!
