Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Ragg Topp application
Old May 30, 2007 | 10:37 AM
bugn's Avatar
bugn
Originally Posted by JVM225
I think I'm going to try the brush recommended by Bugman in post # 12 above.
Me too.
Old May 30, 2007 | 12:57 PM
loflite's Avatar
loflite
Curious, I have raggtop and have not yet put it on my new '07. I did use it on my '95 and did not mask anything. I just wiped the overspray immediately. Is there any real damage done by the overspray? thanks.
Old May 30, 2007 | 01:01 PM
Jet-Jock's Avatar
Jet-Jock
I don't know for certain. I just didn't want the mess to clean up. I did it once before about 3 months ago or something like that and I only covered part of it just beyond the windshield. When I was done the finish had overspray all over it. So I had to use detailing spray and wipe it all off. I did mine in the garage with the door closed. This time even though I covered it up I had the garage door open. Fans on both times though.
Just didn't want to hassle with it getting all over everything. And this was my trick to doing it.
Old May 30, 2007 | 01:14 PM
bugn's Avatar
bugn
I was just looking around when i came upon this. Isn't this the company that makes the vette top? They recommend this brush. Not trying to start trouble just want to be sure we have best brush.
http://classic-motoring.stores.yahoo...topscrubb.html
Old Jun 2, 2007 | 02:36 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by Jet-Jock
Just goofing off this afternoon. Applied the Ragg Topp sealant. Here's some pictures of the vert sealed off with 1mm plastic dropcloths. I used some painters tape and some paper under the direct edge area of application and then slipped the plastic (new only) over the rear and front with the top collasped up and folded it down on the plastic. Sealed it off pretty good and tapped off the rear window and side weatherstrip.
Top should be good to go for a few more months of summer!
after a couple coats:
Done and ready to remove the prep work
Excellent work by you!...You just gave me the inspiration to do mine
Old Jun 2, 2007 | 08:31 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
Quote: How do you clean bird droppings off on a fabric top? Thanks.
Do not use Bug & Tar remover as they are formulated with strong hydrocarbon-based (aliphatic) solvents that will deteriorate the water repellent coating.
Alternative product- this product will remove it without damage to both vinyl and cloth. It will not harm the tops water repellence. Poop-Off Bird Poop Remover is a non-toxic, biodegradable, active enzyme formula that removes droppings and residues composed of all types of avian diets including, seeds, fruit, nuts, meat, vegetables, nectar, bugs and grains. Originally a marine product, it will not harm the tops water repellence Product specific - Poop-Off Bird Poop Remover Properautocare
Old Jun 2, 2007 | 12:53 PM
Jet-Jock's Avatar
Jet-Jock
I just use the ragg topp cleaner if something gets on the top, otherwise just the regular Zaino car wash along with the rest of the vette.
Old Jun 2, 2007 | 11:26 PM
bugman's Avatar
bugman
Originally Posted by bugn
What section did you find this brush?
At ACE, they keep it in the isle with the other car products.
It is sold for use in washing your paint, but I would NEVER use any brush on the paint.
For birdbombs, just spray with a water bottle first - let the water sit on it for a few minutes, then jet it off with a hose, or use your brush. You'll see that not much sticks to the fabric if it's protected by Raggtopp.
Old Jun 2, 2007 | 11:28 PM
bugman's Avatar
bugman
No there is not.
if it gets on the paint, you can use a quick detailer and cotton towel to remove it. It may cause your wax to smear, though, so best to make some small effort to protect the paint (like just lay a beach towel over the trunk area when you spray).
No harm to the glass - comes right off with any window cleaner.
Old Jun 3, 2007 | 05:29 AM
bugn's Avatar
bugn
Thanks. I will now know where to search. Thanks for all the information. Very helpful.
