Help Please! Major problem using PC
The Z5 took care of the slight haze, a haze that Z says may be there with ZPC. You are now trying to bring the haze back???
I would say go back and complete your polishing on the rest of the car.
Another thing you could do is apply two or three coats of Z5P, and two Z2P to your hood and see what you think.
Or you could wash your car with any old rag, induce some swirl marks, and then maybe you will be happy?
I just don't trust the idea that you have to put Z2/Z5 on after the PC-Fusion to remove the haze. It shouldn't have a haze at all, IMO. The whole thing makes me nervous that the fusion is screwing something up, and then you have to layer another product on top to cover it up.
For example, if I allow myself 3 hours to work on just the hood alone, couldn't I remove more imperfections by doing multiple passes with orange & 83 to start out with since it would cut so much better? I could spend the first two hours working that combo many times, then spend the last hour polishing it off nicely with M80/white pad, getting rid of any micromarring that the first combo might've created. If I just stuck to the white pad the entire time isn't it possible that I might not remove as many imperfections?
If you're a pro detailer with extensive experience, then you just use the rotary to do your paint correction, and (if at all) use the PC for a quick pass for your finishing work. If that's your situation, then you don't need to use more than a white pad on your PC.
If you're a regular guy, (no rotary), trying to do paint correction, it would take forever with a white pad on a PC - in fact, for me on a Vette, I really cannot accomplish anything at all with a white pad. I use an orange pad with MIP and often stop there because the finish looks perfect to me. Sometimes remove light defects with orange/ZPC combination.
My own opinion is to stay away from the Lake Country Yellow pad with the PC because you might cause marring that is difficult to remove by PC (but could be removed qutie well with the rotary). I use the orange pad all the time with no problems. But if the orange pad and MIP will not remove a defect, then I go to my rotary.
Sorry I have no experience with Meg#83 - you might want to send TH0001 a pm and ask his opinion about using it with an orange pad.
Z-5 is removing the hazy residue.....
If the Z5 is somehow removed, will the haziness reappear?
No....
too much ZPC ? never thought of that causing haze.
I've never seen the haze like this from Zaino PC on black.
I HAVE had some hazing with 3M #39009 on black, when I overworked the polish past the point of drying. Agentf1 helped me fix that in the past.
good info
ZPC is not that aggresive, I've never had any haze with it, I just used it on a black Lexus tonight (very soft clear btw) and it finished down perfectly.
Of course I don't put it on too thick, and I work it in plenty till it's almost clear, then wipe off and the paint looks like.......WOW!!
The way I work it in, is starting off on speed 3, spreading it all around, then once spread I jump it up to 6 then work it in real good for a little a couple minutes moving over the surface slowly, then once worked in, go over it faster to insure it's finished off.
Wipe clean. No residue, no haze or anything....
Josh
It makes no sense, but it's true.
But on my Victory Red Vette, fantastic - can't live without it.
I'm not giving up on CS - because of how great it looks on my Red. I think it just takes a little while to learn how to use it.
Don't give up on CS- next time just do a very small test area - walk away for a half hour , come back - see if you can practice a few times and determine
- how much to spray for best results
- how close to the paint to spray it (I'd recommend about 4 inches!, while you are actually moving the bottle across the paint and spraying)
- how quickly you can spread it with the applicator -
Big problem is that if you do this outside, esp in the heat, you may get very tiny droplets of overspray blowing around, which ruin your finish - be sure to use CS inside only.
