Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
View Poll Results: what's the next step?
PC (random orbital) and abrasive product
4
57.14%
Rotary + abrasive
0
0%
Chemical cleaner - tell me which one.
3
42.86%
Wet sand
0
0%
Voters: 7. You may not vote on this poll
Blobs from outer space
Old Sep 24, 2007 | 04:37 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
Menzerna Products:
Like polishing glass, the smoother you make the paint or clear coat, the more pronounced the reflection. The limiting factor of any polish is the size of the abrasive particle used. The smaller the abrasive, the smoother you can burnish the finish. The very fine tolerance of abrasive particle size used by Menzerna polishes allows for a consistent breakdown and thus consistent micro marring free finish when used. These abrasives are designed to fracture under heat and pressure into progressively finer and finer particles.
These diminishing abrasive polishes are foam pad ‘dependant’ as far as its paint correction / renovation abilities are concerned and they appear to work better when the foam pad is ‘primed’ (a very slightly distilled water dampened foam; do not use a quick detailer (QD) as most are formulated with either a wax or a polymer; however they are not easily adaptable to a spray formula. To be efficient they need to be emulsified to work as a spray, to facilitate this they need to use an emulsion of silicone oils and water. The wax will reduce the friction heat, negatively impacting the diminishing abrasives; silicon-based products can also have a negative effect on the surface / polish lubrication oils used by Menzerna causing surface smearing.
I'm still not convinced that a buffer can produce the friction heat required to breakdown the abrasives used in these products.
I have used a PC with a 'Slow Hand' method to successfully apply these products, but that's the subject of another thread...
Old Sep 24, 2007 | 01:50 PM
User 020720's Avatar
User 020720
I'm still laughing at that 'bug appendix' comment.
Old Sep 24, 2007 | 03:33 PM
daddoe's Avatar
daddoe
Hey Bugman, I'm sure glad you found the culprit to be tar from a pine. I was looking closely for imprints of body markings being pressed up against the hood
Old Sep 25, 2007 | 02:03 AM
bugman's Avatar
bugman
HAAAAAAA !
well, the evidence for pine was only circumstantial.
hadn't thought to have DNA testing
but it sure was tough to get off...
you guys are a sick bunch!!
Old Sep 26, 2007 | 12:30 PM
pinkandgreen's Avatar
pinkandgreen
1st Gear
hello everyone, it's me, the sis-in-law in question, and the owner of the shameful passat thank you scott for going above and beyond your duties as a bro-in-law. my car's never looked better. in fact, when i rtnd home my landlord came out, glass of wine in hand, musing as to whether or not i had gotten a new car plus, i realized as i pulled into my usu spot that i've been parking under a tree for the past year thank you everyone for the laughs! i'm sure i will be making an appearance again in the future
Old Sep 26, 2007 | 06:05 PM
bugman's Avatar
bugman
AHA !!!
Thanks for the post, sis
hey -- I love that car - try to keep her out from under the trees
and next time - leave your husband and a case of beer here when you leave town!
Old Sep 26, 2007 | 11:25 PM
C4boy's Avatar
C4boy
Ok, Mrs. Passat, now that your car looks like new again, heed your brother-in-law's advice on upkeep. If he comes back in 6 months with more pictures of bug spleen and nuclear tree sap, you may find a group of crazy car detailing guys paying you a visit in the middle of the night! Beware, if you find car wax wrapped up in newspaper on your door step j/k
Although, if you need bugs removed from your front end, who better to call than the "Bugman"
p.s. I noticed you didn't use the z16 on the V-dub
