I have a high powered 235mph leafblower. The air that comes out is not contaiminated or anything, could you dry your car with one of these and forgo using the drying towels or chamois?
Best way to go!
Remove the nozzle from your hose for the final rinse and watch the sheeting action take an incredible amount of water away.
Use the blower for the remaining 90+% of the water.
Follow up with a light Z6, and a quality towel for a spot free shine.
Best way to go!
+1
Exactly what I do, Z6 or Z8 will keep it nice and slick too. You'll be amazed (if the cars is properly waxed up) at how easily the water blows right off. I find it easy to start at the top and blow the water downwards, the gravity helps it get off easier.
I have a small electric hand held powered leaf blower. Small but powerful. I use it on my street rods and vette. Final touch up with a micro fiber towel. Cars come out spot free.
Tip: I do the wheels, tires, and the mirrors first, then work from the top down with the blower. You will also figure out the nooks and crannies that hold water.
Thanks Guys,
TBonez
I do it every week or so. After I dry my car with my electric leaf blower I give it a few spritz's of Zaino Z6 quick detail spray and use a good quality MF towel. I get that "just applied" look month after month in a fraction of the time.
Cool so when you wash you don't take your wax off right? Then just leafblow dry and apply Z6 right?
Correct. I only remove my Zaino about once a year. Typically in the spring when I go over the whole car with a buffer.
I apply my Zaino products and it's good to go for about 6 months. I'll throw on another coat of either Z2 or Z5 at that time.
For normal weekly washes, just wash, dry with a leaf blower and then spritz with Z6. Maybe once a month or two I'll give it a spritz of Z8 to amp up the shine a little.
