Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
bon-ami for cleaning glass
Old 01-02-2008, 05:12 PM
nmk
nmk's Avatar
Default bon-ami for cleaning glass
I read somewhere on here that bon-ami works really good for cleaning glass. I bought some today and am reading the back and it says "do not use on glass or mirrors" So has anyone ever used it on glass? Thanks!
Old 01-02-2008, 06:17 PM
agentf1
agentf1's Avatar
St. Jude Donor '10
Yes, I have used it in the past and it was just OK. I recommend something like Zaino's Glass polish over the cleanser.
Old 01-03-2008, 05:40 AM
TOGWT
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
Bon Ami:
There are two kinds of Bon Ami - the cleanser and the powder.
1. The cleanser - is in the round can that you can buy in the supermarket, it contains feldspar, calcite, and soap. It will scratch glass.
2. The powder - contains feldspar and soap, was used to clean the windows in Skylab, and is available in either a rectangular can or as a cleaning cake. You can't get it at the market but have to go to the hardware store or online at http://www.agelong.com.
Old 01-03-2008, 09:01 AM
nmk
nmk's Avatar
Well I got "polishsing cleanser" in a round can, so I guess I picked up the wrong stuff.
Old 01-03-2008, 10:13 AM
Tom/99
Tom/99's Avatar
I use Bon-Ami on my windshields often. Iit really cleans the road film off, and keeps the wipers working smooth. I've never had a problem with it scratching my windshields. Don't use Comet, Ajax, etc. only use Bon-Ami.
Old 01-03-2008, 12:40 PM
69er
69er's Avatar
True.
Zaino or any other true glass polish is easier to use and less messy than Bon Ami.
Old 01-03-2008, 06:53 PM
C4boy
C4boy's Avatar
If you see 2 on the shelf in a supermarket, I think the one you want is labeled as "The Original" on the can. I forget as I haven't bought it in a while. It will say on the directions that it's safe for glass.
Old 01-04-2008, 03:25 PM
IAIA
IAIA's Avatar
Originally Posted by 69er
True.
So glass "polish" is more than just a cleaner, like Stoner's? Does it abrade, or just protect/clean? I used my PC on my windshield with some ZPC-Fusion, and it helped smooth things out.....weekly, though, I just use the Stoner's. Is Zaino glass polish more like the ZPC, the Stoner's, or neither?
Old 01-04-2008, 04:00 PM
69er
69er's Avatar
Zaino and Griot's Garage a very good glass polishes.I'm sure other companies also.
It's not a spray,it's an actual polish that you rub on and towel off.
It cleans road grime,road oil,waterspots etc.No abration that I'm aware of.I've been polishing my vehicles windshields 4-5 times a year for many years without any problems.
I guess ZPC would work too.
Old 01-04-2008, 06:42 PM
agentf1
agentf1's Avatar
St. Jude Donor '10
Originally Posted by TOGWT
Bon Ami:
This is true, I searched far and wide trying to find a place that carried the powder and not the cleanser. I forget where I finally found it. The reason I searched for it was because I had water spots all over the windows of my 88 vette which wre there when I bought it. They musrt have been etched pretty good since the Bon Ami did not touch them. This was before I knew about Zaino so I cannot draw any comparisons.
Old 01-05-2008, 11:32 AM
JJU
JJU's Avatar
Cruise-In II Veteran
The Bon-Ami you may be referring to has the following on the label:
- Professional Formula
- Glass Cleaner
- Cleans and Dries Faster
- No Streaking
- No Ammonia
- Safe for use on PlexiGlass
I picked up a can at a local Tru-Value Hardware store. I had to order it
in special. I thought it was a bit expensive (almost $5 with tax).
You may be aware of the Guru Reports magazine of 2003. I believe
the product above is the successor to the product they reviewed as #1
then called "Glass & Surface Cleaner".
I've been comparing it to my personal favorite, Sprayway. Both do an
execellent job. The Bon-Ami doesn't foam as much as the Sprayway.
You can really smell the ethyl-alcohol in the Sprayway. I don't know if
there is any ethyl-alcohol in the Bon-Ami. There is no content label on
the can. My test continues.
The Zaino Glass Polish (Z-12) is not for everyday use. You need to
supplement your arsenal of products with a cleaner.
Old 01-05-2008, 02:18 PM
maxp
maxp's Avatar
another great product for cleaning/polishing your windows or windshield is Klasse AIO
To bon-ami for cleaning glass
Quick Reply: bon-ami for cleaning glass
