Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Which model leaf blower?
Old Feb 15, 2008 | 12:30 AM
Missile Maker's Avatar
Missile Maker
Default Which model leaf blower?
For those of you that use an electric leaf blower to dry the majority of your car, which one do you use? And what is the mph rating? I have a small one that puts out 140mph. Worked OK. Wondering if a higher power one is actually worth it.
Old Feb 15, 2008 | 04:04 PM
IAIA's Avatar
IAIA
I'm just bumping this up for you. I use an older combination ShopVac that also has a blower, but I don't know the mileage rating. It works, is all I care about. Others have talked about a Toro with a MPH of 200-220. Best to search for the thread using "toro" or blower, but comfine it to the car care discussion in your search.
Old Feb 15, 2008 | 07:59 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
Ive had my BD Leaf Hawg for over two years without fail ....
Old Feb 15, 2008 | 08:59 PM
jimmybobby's Avatar
jimmybobby
Active Streak: 90 Days
Yes, I modded my leaf blowers. The B&D was rated at 200 mph I think - forgot the cfm. It was $39.99 at Home Depot.
Old Feb 15, 2008 | 11:56 PM
tfkrato's Avatar
tfkrato
I use my gas Homelite blower I bought years ago at Home Depot. Works great on leaves, grass, and drying the Vette.
Old Feb 16, 2008 | 08:00 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I use an electric Toro I bought at Home Depot for around $40.
I think it has a rating of +200 mph....works great...
Old Feb 16, 2008 | 09:02 AM
MY93TOY's Avatar
MY93TOY
Ysterday I purchased a Homelite 7 Amp 150 MPH Electric Blower from Home Depot for 29.99. I have not used it yet but I figured for the price I will give it a try. Dose anyone have this one?
Old Feb 16, 2008 | 09:48 AM
96vetteLT4's Avatar
96vetteLT4
nice to have a garage with an air compressor, set psi to where you want. A long extention about the diameter of a pencil will get in a lot of spaces a leaf blower wont. If you dont have one think about getting one. Even small ones will get the job done and provide alot of other uses....G
Old Feb 16, 2008 | 11:58 AM
MY93TOY's Avatar
MY93TOY
I have a air compressor. But sometimes I have water that will blow out on my car.
Even after I bleed the water out of the tank.
Old Feb 16, 2008 | 01:25 PM
Missile Maker
My toro is very similar. Seems to work fine, but could use a bit more power. I think I'm going to exchange my current one for the next higher model.
Thank you all for the input, it's nice having experienced people to ask.
Old Feb 19, 2008 | 08:29 AM
hcvone's Avatar
hcvone
Toro, I have several.
Old Feb 20, 2008 | 10:11 AM
VETTEHIGH's Avatar
VETTEHIGH
Default Simply the best:
STIHL BG 85
Top-of-the-line hand held blower for commercial applications.
Technical Data
Model BG 85
Displacement (cm 3) 27.2
Power (kW) 0.8
Weight (kg) 4.2
Max Air throught Put (m3/h) 780
Maximum Air Speed (km/hr) 295
IT COST ME $230 , BUT IT WILL BLOW THE HOUSE DOWN
To Which model leaf blower?
