Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Black top cleaner/treatment
Old 01-15-2009, 03:38 PM
Bkueffler
Bkueffler's Avatar
Default Black top cleaner/treatment
what is the most popular or recommended product for my c6's black top?
Old 01-15-2009, 05:57 PM
PowerLabs
PowerLabs's Avatar
Location: Greater Detroit Metro MI, when I'm not travelling.
Wax it like you would any other body panel
Old 01-15-2009, 06:36 PM
k0bun
k0bun's Avatar
Location: NJ..."the way I saw it, everyone takes a beating sometimes."
*ahem* Convertible....
This gets a lot of good reviews.
http://www.autogeek.net/racotopcakit.html
Old 01-15-2009, 06:56 PM
PowerLabs
PowerLabs's Avatar
Ops! My car's top is black too but I don't have a convertible... My bad
Old 01-15-2009, 06:59 PM
patton
patton's Avatar
St. Jude Donor '09
Old 01-15-2009, 09:32 PM
steve8
steve8's Avatar
Raggtopp kit.
Don't get the protectant on the paint.
Old 01-16-2009, 11:02 PM
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
Convertible == Ragtopp
Painted Top == any wax or sealant
Glass Top == Plexus of DP Plex All
Old 01-17-2009, 05:00 AM
TOGWT
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
Rode & Schwalenbert Gmbn. (Germany) the world leading manufacturer of automobile convertible tops exclusively recommends Harrtz RaggTop Cleaners and Protectant. Developed specifically for cleaning, re-proofing and preserving convertible tops, these cleaning kits consist of two products:
1.Cleaner to remove soiling, stains and atmospheric pollution for both natural and synthetic materials. The best cleaners are formulated from low-pH (low alkalinity) and gentle enough for repeated use over years. They will rely on proteins and enzymes for their safe, but effective, cleaning power.
2.Fabric protector to re-proof and preserve fabric tops from the effects of water absorption, surface soiling and staining, and provide a sunscreen from UV radiation and subsequent fading. It has the best UV protection of any product on the market, and it repels dirt, grease, and oil. It doesn’t make your vinyl top glossy or greasy-looking. It will have the natural matte sheen of new vinyl.
Alternative product- this is the fabric protector recommended by Glen Raven Mills (Sunbrella) and the Haartz Corporation, 303™ High Tech Fabric Guard restores lost water repellence and stain repellence to factory new levels. It stops leaks, resists soiling and impedes mildew formation and helps protect against the sun's harmful UV rays.
Application Methodology
•Use a soft horsehair brush to remove any loose surface dust, use a lint lifter to remove lint from the fabric surface. Be careful around the rear window to avoid scratching
•Mask the areas around the fabric top with masking tape (3M® Painters Easy Release Blue Tape) also cover the rear window to avoid over-spray
•Shake product for 30-60 seconds to ensure even mixing
•With all cleaning products, always test a small, indiscrete area first to ensure it won't discolour or stain the surface, and ensure that the pH of the product is suitable for the material.
•Apply fabric cleaner (Harrtz RaggTop Cleaner) with a clean, damp applicator and leave to penetrate fabric for 10 – 20 minutes dependant upon stain. Gently scrub using a soft brush.
•Repeat if necessary; applying two light coats are better than the application of one heavy coat: allow drying thoroughly between coats.
•Rinse off using a low-pressure water hose and a soft horsehair brush
•Dry with a waffle weave Microfiber towel using a blotting motion to dry excess moisture.
Allow the fabric to dry for as long as possible (preferably 24-hours) before using the protectant. An hour or two isn’t long enough, it may feel dry but that’s only the uppermost surface layer (using a protectant on a damp fabric will ‘seal in’ the moisture and encourage the formation of mildew)
•Apply a fabric protector (Harrtz RaggTop Protectant) on the dry fabric, keeping about 6-8 inches above surface and using a back and forth movements spray lightly but do not soak.
•Alternatively use a soft horsehair paintbrush and apply light thin coats, if time permits, two light coats are better than one medium coat, using gentle sweeping motion. Do not saturate. Allow to dry 10-15 minutes between coats, and to dry thoroughly before using or storing.
•Remove all masking tape and any other materials
•Be sure to remove any accidental over-spray from paint or glass surfaces immediately with a damp Microfiber towel or a 1:1 isopropyl alcohol / distilled water solution. On paint work use a pre-wax cleaner if necessary or fine detailing clay.
•After treatment the top will bead water, when the beading diminishes (usually at 6 monthly intervals, dependant upon climate / use) it's an indication that it's time for another treatment.
Maintenance- Normal cleaning: Use a 10:1 solution of Woolite/ Distilled water and then apply 303 Space Protectant for UVR protection
© TOGWT ™ Ltd Copyright 2002-2008, all rights reserved
This is an except from one of a series of unbiased and informative, knowledge based, subject specific articles, which are dedicated to the automotive detailing enthusiast or professional detailer in search of development and further education
Copyright and intellectual property rights-© This work is registered with the UK Copyright Service All original material is copyright, unless otherwise stated, and may be copied and distributed for non-commercial purposes only provided that you retain all copyright and other proprietary notices contained in the original material and a reference to © TOGWT ™ is included, any unauthorized use of these materials may violate copyrights and/or trademarks
To Black top cleaner/treatment
Quick Reply: Black top cleaner/treatment
