paste or liquid
Seems the paste is harder to use but seems better - any thoughts?
Most chemists agree that when it comes to a wax formulation there is no advantage between pastes, creams or liquids. It has more to do with production cost and marketing than; ease of application or removal, its protection or surface gloss abilities. The only ingredients that will make a difference is wax quality, percentage by volume of wax and its carrier system (i.e. type of solvent / silicone and/or mineral oils used) and wax percentage content
Paste wax is just a thicker form of liquid wax, a different consistency, not necessarily even more or less solvents. All natural waxes require a solvent to soften them (in there natural state they are as hard as concrete and are sold as a solid block or as flakes) Some wax products use an emulsion (oil-in water) to keep more liquid without adding more solvents which, in high concentrations could affect durability as it would dilute the wax content, the emulsion helps to lubricate the paint surface and enables the wax to spread evenly before the solvents flash and the wax reverts to its 'hard' consistency.
Dispensing paste wax- invert the jar on top of the pad; let the wax slide onto pad, angle the jar or squeeze to hold the wax in place, and spread evenly on the foam pad.
