Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Engine Cleaning
Old Jul 21, 2009 | 12:35 AM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Default Engine Cleaning
I'm looking at cleaning the engines on our Vette's. So I'm looking for suggestions on engine degreaser's that I would be able to use on them. I want to get them as clean as possible. Also looking for suggested ways in doing this process.
Old Jul 21, 2009 | 06:31 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
This question probaly hasn't been asked in the last few years, but just in case try the Search button
Old Jul 21, 2009 | 11:44 AM
KGVette's Avatar
KGVette
Simple Green has always worked good for me
Old Jul 21, 2009 | 01:33 PM
ZaneO's Avatar
ZaneO
I would stay away from Simple Green. Too many potential problems with it.
P21 Total Auto Wash is going to be the best option, IMO. Others would be Meguiar's APC/APC+, etc.
Old Jul 21, 2009 | 02:26 PM
MR.WaynesWorld
Would either of these remove built up dirt on the engine... Mine is an 02 but my wifes' is a 99 with over 75K on the clock. So I know the engine is pretty dirty...
Old Jul 21, 2009 | 02:53 PM
ZaneO's Avatar
ZaneO
They should.
Slightly warm the engine. Lightly wet it down (being careful of electronics). Thoroughly apply degreaser to areas needed and allow to dwell for a few minutes, but do not let dry. Agitate heavily soiled areas with a soft brush, and rinse.
Once cleaned to your satisfaction, generously apply a water-based dressing and let the engine run for a few minutes to aid drying and set dressing.
Old Jul 21, 2009 | 02:54 PM
Z06_Joe's Avatar
Z06_Joe
St. Jude Donor '09-'10
If you want a commercial grade all purpose cleaner that has a multitude of uses pick up some of our Extra Special Cleaner. It will have your engine free of dirt, grime, oil seepage etc in no time. Priced very reasonably at $9.95 for a gallon which is concentrated. Also works great around the home.
For your particular application I would dilute it 50/50 for the extremely dirty areas and load it into a spray bottle. Agitate it wil a brush the rinse it off. Follow up with a waterbased dressing and your all set.
Click The Pic Below To Check It Out On Our Website.
Extra Special Cleaner is our premium multipurpose cleaner for interior/exterior use. Extra has the most surfactant (cleaning power) of all the all purpose cleaners we produce and no dye so its great on any surface. Extra works great on velour, vinyl, carpets, as well as tires, wheels and even engines. The unique forumla also breaks down organic stains and leaves a nice fresh pepermint fragrance behind as it cleans. This product is concentrated and has a dilution rate of 4:1 for general cleaning but can be used 1:1 for greasy engine areas. Extra can also be used for cleaning leather if diluted 10:1.
Old Jul 21, 2009 | 06:02 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
http://www.autogeek.net/p2totautwas.html (P21S)
or
http://www.autogeek.net/optimum-power-clean-apc.html (Optimum on BOGO)
both are great products for grime and dirt. Remember to coat lines with a non-silicone dressing like 303 and use Klasse AIO on painted parts. Often wiping down engine bay monthly avoids the need for harsher cleaning and water.
Old Jul 21, 2009 | 10:38 PM
Black04Z06's Avatar
Black04Z06
P21 I've had good result with it.
I like Simple Green for cleaning non aluminum parts / things only, It can discolor aluminum. Not worth the risk IMO.
Old Jul 22, 2009 | 08:23 AM
MR.WaynesWorld
or
Of these two products and include Meguiar's APC+, which would you consider the best product for all around cleaning? Such as wheel wells and engine bay.
Also can anyone provide any words of wisdom concerning this area, I want to clean under the FRC's on the engine (where the coil packs are). These can get pretty dirty and would like to clean them up as much as possible.
Old Jul 22, 2009 | 02:53 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
P21 TAW is great for engines!
or you can take a trip down and we can break out the dry vapror steamer
Old Jul 22, 2009 | 06:06 PM
Former Vendor
P21S Total Wash is so versatile, its my personal choice. Amazing Roll-off is about the only other product I might consider and use it for tires/wheelwells and wife uses it on PVC porch furntiture and stuff. I have never used ARO on engine personally.
Old Jul 24, 2009 | 02:51 PM
MR.WaynesWorld
Now that sounds interesting... I may take you up on that offer hopefully before the season ends. Just have too many things going on right now...
Old Jul 24, 2009 | 04:39 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
When using P21S Total Wash on the engine, is rinsing necessary or just wipe off? Are there any surfaces or materials in the engine compartment to avoid when using P21S?
This sounds like a great product and I am thinking about ordering right now!
To Engine Cleaning
