Another Polished Wheel Question
I recently got an 06 with polished wheels. They are in great shape but I would like to get more shine on them. I did a search and found that they are coated so I should not use metal polishes but paint polishes are OK.
My question is will the Mothers Power Cone damage the clear coat if used with a paint polish? My orbital buffer is too big to be much good on the wheels and the Power Cone would work great. I bought one but noticed in the directions it says for uncoated metals. Maybe they are assuming it will be used with metal polish; or maybe the cone on a drill will cut through the clear coat with any polish. Does anyone know?
Former Vendor
Ive have used the Mothers Powerball Mini with paint polish on coated wheels without issue, but use it carefully. You will never remove 100% of the milky white coloring but from 10 feet back they will often shine just like chrome. Use a good sealant on them too and it will reduce cleanup sessions, Blackfire Crystal Seal is my current favorite.
Probably the best thing to do but I just bought the car and am adding a Corsa exhaust and a transparent top; I need to stop the bleeding.
