Your claybar and claymitt tips n tricks plz
Tomorrow...me and the lady have a spa day. It's been too long.
My plan:
Wash car and wheels
Claymitt the car while stubborn bugs on my front end with Xpel soak with hot water and paper towels laid over this areas. ( NOT claying the PPF)
Then...should I re-wash again for just give her a good hosing off?
Dry
Then microfiber cutting pads pads on my griots DA with meguiars 105
Then foam pads for Chem Guys V38, Blacklite and Jetseal.
Questions:
as I asked above. Wash again or just rinse?
Some PPF seams have that white outline from previous waxing. Your ideas on cleaning that out. I have a few in mind but wanna hear your experience.
Tips for stubborn blemishes on the Xpel?
Thanks fellas.
My plan:
Wash car and wheels
Dry
Questions:
Thanks fellas.
Also, I've never used M105 or micro fiber pads.
I'm frustrated with the lack of correction using the orange and yellow foam pads with Chemical Guys V36. It just seemed to not get it all. Ya know.
So...
So, gonna do a small area with M105...see how much more it bites. Then hit it with V38. You can bet I'll be sweating a little more while using M105 first time. I'll probably baby my pressure first few passes and sections.
So...
My plan:
Wash car and wheels
Dry
Questions:
Thanks fellas.
My plan:
Wash car and wheels
Dry
Questions:
Thanks fellas.
Lines on your Xpel- if it's really caked in there, a boars hair lug brush with a little all purpose cleaner should do the trick. If it comes off with your finger nail, a micro fiber towel is safer.
Lastly you can polish the Xpel just like you would your paint but I would test the spot with m205 first. Always start with the least aggressive and see if a couple passes will work without breaking out the 105 which is more aggressive.
Good luck and take some before and after shots!
Vetteman1980 (07-11-2017)
So...
So...
ronkh57 (06-27-2017)
After the wash go right to clay. (MIT or bar) then if you're using a clay lube I would wash again just to get rid of all that. I know guys that think it's a waste of time since you're going right to polish but I like to know there's nothing on the surface of the car before polish.
I don't think it's caked too badly. I was thing of spraying some quick detailed and using a wooden tooth pick to trace around. Pressing lightly being careful not to lift the film
I don't have M205, just the 105. I have a bunch of Chemical Guys polish I wanna finish up. The V38 polish then the other two products.
Cleanup on edges- tooth pick will work, but like you said be careful not get under the film. I would come at perpendicularly rather than parallel so you're not risking that lift.
Good luck
I was using V36 with orange and yellow foam pads. Didn't seem to do enough.
So far(quick meal break) I'm liking the M105 and micro fiber pads. Broke my 3" buffer plate tho. I'm not pressing too hard as I learn the performance of this combo. A few lone scratches remain but way better. As I gain experience...next "spa day" I'll be more aggressive on these.
Also, the M105 takes some extra effort to buff off. Am I using too much and/or not working the stuff long enough?
I do that kind of pattern. And I do see the M105 get that look, but I was stopping around that time. I'd give about 3 passes. Say, up down, left right, up down. I was just concerned about being too aggressive.
I was even more afraid of using it on the Xpel. The only thing I've done on Xpel is polishes with soft pads. You've used M105 on Xpel? I think I would use the orang foam on the PPF. The micro fiber pads would be too much I think
