Opti-coat Pro & Pro Plus+ cost
Greetings,
In the Austin, TX area, I received a quote of $899 and $1299 for Opti-coat pro & Pro Plus+ respectively. I take it that the process is labor-intensive and that the prep work takes the most of the time than the actual application of the coat. So,checking to see if these prices are in the ball-park and if there are other options around here.
It would be in the prep. You need to find out what steps will be taken ( a 1 step or 2 step correction) percentage they expect to be able to correct. Are they using a PTG prior to correction? Look at the shop conditions-cars they are working or have worked on. Did they info you of what steps or products to use to maintain the coating? Do they have to clean it keep warranty going...
