Ceramic Coatings
N' it came out FANTASTIC!
My Viper has the CQuartz ceramic coating and it's 1000x easier to maintain than the daily that got waxed 2x a year.
It's not hard and it's not rocket science. It's just labor intensive and literally took 3 days to finish. But I did take my time and didn't rush the job.
97% of the work is prepping the paint/clearcoat. Applying the ceramic coating was the easiest and the least labor intensive step.
I used
I got the Harbor Freight Dual Action Polisher ($69) and light/medium foam cutting pad and it worked just fine.
The work flow is:
- Strip the finish of waxes and everything. I washed the car with a multipurpose cleaner (Simple Green) and then hit it with a Clay Bar & Lube spray (
Do this outside in the Sun light. - (in the Garage) Polish with the Dual Action Polisher. This is by far the most labor intensive step. The trick is to determine the right compound polish and cutting pad to use for your paint. This is the only place where the pro's have the edge. They have all the different grades of polishes and cutting pads to test with to determine which combo is best for the condition of the paint/clearcoat. This is also where the "color correction" gets done. The goal is to remove all the scratches and swirls (n any other defects) without doing any damage. I got into a little pickle on this step. I ordered what I thought was going to be the right polish and cutting pad and it got back ordered.. so I went to Oriellys and bought a light/medium polishing compound by Mothers. Turned out it wasn't really recommended for use with Polishing machines.. which just meant that it heated up and broke down too fast. It worked OK everywhere except the hood. On the hood, also used McGuires Scratch-X 2.0 and that did a pretty good job of removing the swirls. I basically worked with the polishes and cutting pad I had on hand and it all worked out great.
- (in the Sun light) Clean the surface AGAIN of any left over oils and gunk from the polishing step. There are all kinds of product$ for this step OR you can make your own diluted Isopropyl Alcohol solution for practically no $$. Which is what did and it worked fine.
- (Garage) Apply the CQuartz. Follow the instructions. It goes on super easy. By far the easiest step.
- (in-between step.. after about an hour) - if you're going to add a top coat like
, this is the time to do it (but do follow their instructions). OR hit it with a silica based
Detailing Spray like .. which is what I did. Also note Gliss can be used instead of CQuartz.. research and decide for yourself. - Let it cure for 24 hours.. Don't drive it, just let it sit in the garage.
Follow steps above for paint prep, polishes like Meguiar's M205 can be found easily at your local Walmart/Harbor Freight. I use IGL F1/F3 combo on an IGL yellow pad and I love that combo before coating! I am an IGL Kenzo Certified Installer in SC.
I did try Gyeon Skin on another vehicle and I am impressed with it. It is only a week coated at this point, but happy with results. I had better results in terms of application with the Gyeon Skin topcoat than the Kamikaze ISM coat. The ISM coat is worth the extra effort, though, as it produces a more carnauba like appearance.
I would recommend either, but would put Kamikaze at the top.
|As a Pro detailer, I would say BudgetPlan1 and myself have tried just about every coating on the planet. From a consumer perspective the Kamikaze line is heads and shoulders above anything else I tested. From a Pro perspective Feynlabs is up and coming and has simply impressed me with it's quality and final finish. Way above Ceramic Pro, or Kamikaze.
With the amount of new products appearing daily, it's an endless quest.
I'm kinda curious as to what the next potential game-changer will be...new coating releases are so frequent now it's kinda getting mind-numbing.
That said, Feynlab has always impressed me with their organization and products. On a consumer level, their Ceramic + Topcoat combo is a great, not too $$ option and has *the* most brilliant gloss of any I have used. Very easy to use as well.
I wonder if self-healing will trickle down to consumer levels at some point?
