Took the C7 in for a FaceLift... for the second time.
After I purchased my car I had it Ceramic coated, they were suppose to do a full paint correction and seal it up with the coating. I bought it used and admittedly did not have a perfect finish. When it was dropped off (late evening the prior day) I was told they would get on it in the morning and should be about one week. The next day they called (around 2pm) and said it was all done. I thought wow that was quick, but in hindsight was a big red flag. When I picked it up it was getting dark and was a cloudy sky, so not much light. Looked pretty good and I asked how it was done so quickly, they said that it was in such good shape it didn't really need much polishing. I didn't think much of it.
First time in the sun I noticed there are still spiderwebs. I've had it back to the shop twice to correct the flaws and still looks the same in the sun. So last week I took it to another shop for a second opinion. He was honest and said that the prep was not done (coating was applied but no way full paint correction was done). Here is where I'm confused, he said that I've also introduced webbing to the coating. I don't understand how I can be putting these micro scratches into the coating? I thought ceramic was harder and wasn't suppose to be as susceptible to scratching.
Swirls are bugging the chit out of me and he is going to get things sorted out. Not going to coat the car again as I don't see the point in a coating that is no better than the paint.
My wash process (with soft water):
As I write this down and see it in black and white, I think #3 is where I'm messing up and introduced defect to the coating. Sometimes you just need to work it out in writing and you'll see the issue. I'm not retyping all the above, so what say you?
This detailer also mentioned that micro fiber is not as safe as they claim it to be and I shouldn't be using it for washing? Suggested synthetic wool? Anyway, should have it back by the end of the week and hopefully it will look as good as the pictures in my head
- power wash the car
- foam cannon car (Chemical Guys PH Neutral Soap)
- ***See note below***
- single bucket with PH Neutral Soap and 12 Brand New Microfiber towels
- one towel from bucket per panel (towel never to return to bucket so water/soap can not be contaminated)
- rinse panels with power wash as you go
- wash wheels with remaining clean water/soap in bucket and wheel wooly
- warm water rinse with garden hose
- blow dry with leaf blower
- separate laundered micro fiber for each door jam, under hood and rear hatch to dry those area
- new micro fiber used to apply detail spray
Coating can be removed, but obviously is labor intensive and has a dollar amount attached to it.
