Summers here and so are those little basta**ds Wondering what is a good product to remove them. Did a search and some are recommending hydrogen peroxide. Any others good products out there
agreed. Also PB's Bug Squash and Stoner's Tarminator. If just a bug or 2 I place a microfiber wet with fairly warm water on it for a minute or 2 till the proteins soften and then a very gently swipe and they come right off.
Same. Previously used both the Poorboy's World and the Griot's bug removers. And +1 on the wet MF towel method!
I use our Waterless Wash, spray let soak while wiping down the rest of the car. Go back and do the bugs last.
The key is not to leave them on get them off ASAP. For older bugs you may need to clay to get them removed.
I use Kenotek "Anti-Insect". Dissolves bugs in a couple minutes.
Where do you get this product? Also I have heard WD-40 works. Need a good product for tar also or whatever that black stuff is that comes off the roadway and usually gets on side of car and up on wheel wells.
Xpel is on both of our vehicles so I don't worry about etching the paint. What I do is wash the area that has bug residue on it and go over the washed area with a wax/polish that is safe for Xpel. Seems the more I wash and polish the less residue I find.
Hopefully the damn lovebugs will be gone in a few weeks....until September.
