Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
How often do you use your DA buffer?
Old Jan 6, 2020 | 05:24 PM
LS1AB's Avatar
LS1AB
Default How often do you use your DA buffer?
Just wondering how much use you get out of your buffers? If you get your car cut, polished, and waxed well, what more do you need the buffer for. I am debating whether to just take it to a good detailer and have it done professionally for the cost of buying the buffer and product.
Old Jan 6, 2020 | 05:38 PM
FYRARMS's Avatar
FYRARMS
I use mine often...
My daily driver gets a full detail in early spring after making it through Chicagoland winter. In mid-summer it gets a re-application of sealant. In late October, it gets prepped for winter, which includes a light machine polish to prep the surface for the winter sealant I use. My Z06 is garage-kept and sees no adverse weather, but still gets a full detail in the spring when she comes out of hibernation. It gets a second wax application in mid-summer. I use my machine to not only correct the paint, but to also apply glazes, sealants, and waxes. It makes the process 10X easier.
I also will occasionally detail friends' vehicles a couple times per year. In fact, I am actually buying a second machine with more power to make corrections easier and quicker, and I have already installed a 3" backing plate on my Porter Cable so I can use it as a dedicated "small area" machine. Just used it Sunday to detail my friend's Harley bagger using 3.5" pads. It worked great!
Old Jan 6, 2020 | 08:55 PM
jrobin1's Avatar
jrobin1
So is there a practical number of times that you can "correct" the paint before the clear coat is worn out?
Old Jan 6, 2020 | 09:24 PM
03 Owner's Avatar
03 Owner
Originally Posted by FYRARMS
I use mine often...
Which machine are you looking at ? I am just getting into this and I am planning on tooling up.
Old Jan 6, 2020 | 10:16 PM
FYRARMS's Avatar
FYRARMS
Impossible to pinpoint a figure, as there are way too many variables involved: Type of paint, age of paint, chemicals used, pads used, machine used, etc. However, using a random orbital machine and foam pads, you can do quite a few details. Especially considering that once you initially correct the bad surface defects, any future detailing will just be maintenance work using much milder polishes and softer pads.
Good read:
https://www.autogeekonline.net/forum...out-clear.html
Old Jan 6, 2020 | 10:19 PM
FYRARMS's Avatar
FYRARMS
I ordered the new Griot's Garage G9. I considered a larger 15mm long-throw machine, but the G9 should be more than enough for my needs. I just wanted something with more grunt than my 7424XP. Considering the features and warranty of the G9 at the price point, it was a no-brainer.
Old Jan 6, 2020 | 10:22 PM
jrobin1's Avatar
jrobin1
Thanks for that info.
Old Jan 6, 2020 | 10:26 PM
03 Owner's Avatar
03 Owner
Thank you, I'm planning on getting the same unit, along with the G8 for around the front air vents. With the Griots warranty seems like you can't go wrong.
Old Jan 9, 2020 | 12:56 AM
Sixgun95's Avatar
Sixgun95
The G9 has more grunt than the 7424? Can you explain what you mean please?
Old Jan 9, 2020 | 08:03 AM
yamabob's Avatar
yamabob
Neither machine is a "forced " rotation such as the Flex 3401 ( a beast of a machine-but not needed for the person who only does it sporadically). Under certain conditions the pad will stop rotating on these D/A's. This is known as stall. Less powerful machines are more prone to this . The Griots is less prone than the PC. Buffer technique can overcome this to an extent but simply for time and aggravation you want less stall time
Old Jan 9, 2020 | 08:50 AM
Sixgun95's Avatar
Sixgun95
That makes sense, I notice that happening when I break mine out.
Old Jan 9, 2020 | 11:14 AM
Borntorun04/17's Avatar
Borntorun04/17
I have the Porter Cable 7424 I use it on my GS for a full detail in spring and fall . As stated above by FRYARMS it makes applying sealants , waxes etc 10 times easier. So I use it many other times thru out the year detailing my Sierra and wife’s Acadia and GS. Porter Cable really saves me a lot of time and energy. I can’t add anything in regards to different brands / power. Back in 17 I went with what a lot on this forum used and recommend. I have no complaints on Porter Cable. I do detailing more as a hobby and for having my vehicles look great ! Some on forum do it as a living and share great info on this forum. I always learn something new when on Corvette forum.
Old Jan 9, 2020 | 01:00 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I use mine frequently, I even do spot buff if I notice a line or 2 on my Corvette... I do go over things once a season minimum
Old Jan 10, 2020 | 06:46 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
I have two PC 7424 XP machines, one has a small backing plate and the other has a 5" plate. And too many pads lol. I do a light abrasive polish on eight cars each year, and on three of them I also use the PC's to apply a sealer product. So about a dozen times a year. Once you get the paint where you like it, the PC is about all the power you need to maintain it.
Old Jan 11, 2020 | 12:44 AM
John Ulrich's Avatar
John Ulrich
I use my Griots cordless bimonthly for fast "spreading" of Zaino AIO. Inbetween I'll hand apply a fast layer of Blackfire Si02..... on the minivan this is a quick 20 minute wipe on, wipe off event.
If doing correcting, I'll use a Flex 3401. I'm waiting delivery of the new PXE 80 3".
A number of my friends need some hand holding doing their cars. I show them how to operate the machines and they are amazed they can do it and pleased at what they can do. Many are intimidated.
Old Jan 12, 2020 | 11:48 AM
yamabob's Avatar
yamabob
You are going to enjoy the Pixie. !!
Old Jan 16, 2020 | 12:26 PM
PHILLIE PHANATIC's Avatar
PHILLIE PHANATIC
I agree, I got mine before Christmas @ 15% off, I plan on using it this weekend. We'll see how much better it is than my PC.
To How often do you use your DA buffer?
Old Jan 16, 2020 | 01:16 PM
FYRARMS's Avatar
FYRARMS
Samesies! Already swapped to a 5" backing plate and will be using it for the first time on Sunday. My friend's wife just took delivery of a brand new 2020 GMC Terrain mini-SUV. It is a beautiful metallic dark aqua color. Looked at it last week, and it has the usual "brand-new-car-touched-by-a-million-people-before-you-get-it" minor surface defects. Going to clean up the paint with an AIO and some green foam pads. Hoping that will be sufficient to get everything looking its best. I will post a full review thread on Monday.
Old Jan 16, 2020 | 01:41 PM
03 Owner's Avatar
03 Owner
My G9 came in yesterday !! I'm waiting on the rest of the pads I ordered to come in before I get going on my projects. I did put on the 5 inch backing plate just to get ready.
Old Jan 16, 2020 | 02:31 PM
victorf's Avatar
victorf
First used PC on my '05 when new, then '18 picked up the Flex 3401 to prep before I ceramic both Vette and the new '18 Honda.
