Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Applying Zaino with a Buffer?
Old Apr 19, 2003 | 06:56 PM
Bat Man's Avatar
Bat Man
Default Applying Zaino with a Buffer?
Is it safe to do? Any tips?
Old Apr 19, 2003 | 06:58 PM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
Default Re: Applying Zaino with a Buffer? (Marty McFly)
Your better off applying by hand. It is safe to use a machine, but you will end up wasting alot of product.
Old Apr 19, 2003 | 10:45 PM
DsC5's Avatar
DsC5
Default Re: Applying Zaino with a Buffer? (Silver2002)
:withstupid:
Old Apr 20, 2003 | 12:36 AM
Kevin V's Avatar
Kevin V
Default Re: Applying Zaino with a Buffer? (DsC5)
:iagree:
It goes on so easy and comes off so easy, a buffer is even more work, not to mention wasting ALOT of product.
Old Apr 20, 2003 | 10:00 AM
BobbyO's Avatar
BobbyO
I haven't tried this but someone a while ago talked about the great finish they got when they manually applied and removed the polish followed by machine buffing the finish as they misted the paint with water......kind of like a spit shine.
Old Apr 20, 2003 | 11:35 AM
JJU's Avatar
JJU
Cruise-In II Veteran
It is safe.
If you want to prove to yourself that you aren't wasting more than you apply, I would try it once measuring exactly what you use and compare that to what you use by hand.
The people I know only use a buffer to remove the polish.
Old Apr 20, 2003 | 01:00 PM
DP-Jedi's Avatar
DP-Jedi
I use far less product when applying it with my PC than by hand. Much thinner coats and less drying time. I never got the hang of it doing it by hand.
Dave
To Applying Zaino with a Buffer?
