Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Meguiars ScratchX
Old Jun 3, 2003 | 10:57 PM
LT4play's Avatar
LT4play
Default Meguiars ScratchX
Has anybody every tried Meguiars ScratchX?
I have some webbing in the paint of my 1978 Pace, and I am wondering if this will help to hide some of it.
Any other ideas to help with the paint webbing?
Old Jun 3, 2003 | 11:46 PM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
Default Re: Meguiars ScratchX (freemyer)
ScratchX was made to remove minor surface scratches. Most likely unless your spiderwebbing is minor, a touch up or repaint is in order. If they are minor you might want to take it to a well respected detailer to see if they can machine polis (buff) it out using an abrasive.
Old Jun 4, 2003 | 12:09 AM
LT4play's Avatar
LT4play
Default Re: Meguiars ScratchX (Silver2002)
The webbing if fairly minor in most spots (and can only be seen in the right light). Maybe I'll should still try this, and see if it does anything? Or, in your opinion, do I risk worsening the sitation (and I should go directly to a detailer)?
Old Jun 4, 2003 | 12:17 AM
Silver2002's Avatar
Silver2002
You can try ScratchX, but I have never had any luck. If you want to try something yourself first, I would recommend 3M 39009 Scratch & Swirl Remover. Aplly it to a clean 100% cotton cloth and rub it into the surface. Do not let the product dry. Keep rubbing until the product disappears. In my opinion, that is about the best you can do without a machine in the hands of an experienced user.
Old Jun 4, 2003 | 05:43 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
So did you use it???? And if soooo did it work......we would like to know....
tony
:eek:
Old Jun 4, 2003 | 09:52 AM
LT4play's Avatar
LT4play
Hmmm.. I think maybe I will try this product (3M 39009 Scratch & Swirl Remover) instead. Any ideas where can I find it for purchase?
:cheers:
Old Jun 4, 2003 | 09:53 AM
Silver2002's Avatar
Silver2002
It is readily available at PepBoys and NAPA parts stores as well as most auto body supply shops.
Old Jun 4, 2003 | 10:23 AM
RockeVette95's Avatar
RockeVette95
I've used scratchX 3m Swirl mark Remover is the best I've found.
To Meguiars ScratchX
