Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Claying Process??? Difference??
Old Jul 18, 2003 | 01:22 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Default Claying Process??? Difference??
I have never used the claying process before on any of my cars. Does this process make a big difference? Is it extremely labor intensive? Are the results worth the time, $, and effort?
Thanks,
-Rick
Old Jul 18, 2003 | 01:28 PM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: Claying Process??? Difference?? (cicch95)
The claybar is the greatest automotive invention bar none. Yes, do it and you will thank yourself because after you are finished claying you will basically have a brand new super-slick paint surface to work on (polish/wax) :yesnod:
Click on this link
http://forums.corvetteforum.com/zerothread?id=607866
Old Jul 18, 2003 | 01:39 PM
Kale's Avatar
Kale
They aren't hard to use at all, and I can't imagine NOT using the Clay.
Old Jul 18, 2003 | 01:43 PM
DsC5's Avatar
DsC5
Default Re: Claying Process??? Difference?? (Kale)
:iagree:
Old Jul 18, 2003 | 02:04 PM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
Default Re: Claying Process??? Difference?? (DsC5)
:iagree: Preperation is about 85% of a good finish.
Old Jul 18, 2003 | 02:10 PM
Gray Ghost's Avatar
Gray Ghost
Just be careful and use a lot of lubrication under the clay bar. And if you drop it on the ground - throw it away. I tear off a piece rather than using the entire bar.
The Gray Ghost :steering:
Old Jul 18, 2003 | 04:51 PM
cicch95's Avatar
cicch95
Default Re: Claying Process??? Difference?? (Gray Ghost)
OK. Sounds like its the thing to do! BUT...it leads me to a few more questions.....
1) Does using the clay eliminate the need for a cleaner wax before polishing that time?
2) How often should you use the clay?
Thanks,
-Rick
Old Jul 18, 2003 | 05:02 PM
RockeVette95's Avatar
RockeVette95
yes no yes yes and yes.
I clay dawn wash, Swirl Mark Remove, Glaze, Wax,Wax,Wax,Wax..
Old Jul 19, 2003 | 02:00 PM
DetailingDude's Avatar
DetailingDude
From: Chit!! Somebody keyed my Karma and now I'm pissed
Here's an interforum link to a clay bar guide I posted quite a while back. The one thing that isn't on this guide is the putting down of a towel below the car as MY2 suggests. I've never done that before and don't let my towels touch the ground, but I do like the idea. I have so much clay around that I don't have to concern myself with one or two drops. In all my years I've only dropped 2 or so.
The Ultimate Clay Bar Guide
Old Jul 19, 2003 | 04:18 PM
wkasak_07Z06's Avatar
wkasak_07Z06
Default Re: Claying Process??? Difference?? (MilYellow02)
Click on this link
:iagree:
Old Jul 21, 2003 | 02:08 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
it sure made a difference with mine :smash:
Old Jul 28, 2003 | 11:39 PM
painexpert's Avatar
painexpert
Default Re: Claying Process??? Difference?? (Traceys2vettes)
Claying makes a tremendous difference.You can clay your whole car in 20-30 minutes and it is easy to do!!
Old Jul 30, 2003 | 01:31 PM
C5MILLYELL02's Avatar
C5MILLYELL02
Default Re: Claying Process??? Difference?? (painexpert)
And it pretty effortless too...makes it babyazz smooth.
Old Jul 30, 2003 | 06:42 PM
Killrwheels's Avatar
Killrwheels
Default Re: Claying Process??? Difference?? (C5MILLYELL02)
claying is far more scary and intimidating than it is. Use the baggy trick, take and put your hand in a zip lock and rub the top of your car. Every stump or stumble can easily be removed with a quick claying.
** Worst experience -- I dropped one of Pinnacles Polyclay bars in the side vent of the Vette -- it took my friends antenna fished through the door (inside) to get it out. Since then.... I dont drop the clay while car is getting a shower :lol: :lol:
Old Jul 31, 2003 | 11:50 AM
J Z06's Avatar
J Z06
definitely one of the best things to come out as far as detailing a car. what you can't see that's on your finish...and the clay bar pulls it off safely is amazing!
in addition to removing contaminants...it makes your finish the softest feeling it's ever been. once some zaino or your favorite polish is on and it's done, touching it is amazing! slick as glass.
:cheers:
Old Jul 31, 2003 | 04:03 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: Claying Process??? Difference?? (Jay 383)
I used it for the first time last night and it was great. Very easy to do and easy on the hands becuase you don't have to rub hard. Some of the more stubborn marks took a little elbow greate but not much.
To Claying Process??? Difference??
