Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Need Help!
Old Jul 26, 2003 | 09:12 PM
Gate2's Avatar
Gate2
Default Need Help!
I am detailing a tan GMC Jimmy and the driver's side mirror is defective and leaked oil on the drivers' door. I tried the basics to remove this stuff, including claybar and even rubbing compound, but no luck. What else can I try? and what kind of oil does GMC put in those mirrors?
Old Jul 27, 2003 | 11:40 AM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: Need Help! (Gate2)
You won't be able to generate enough heat by hand. The polishes and rubbing compounds today need to really heat up to be effective hence a random orbital buffer like the Porter Cable.
I would use a yellow colored pad and try Meguiar's or 3M paint cleaner. If the clay had no effect, this nasty oil has eaten into the clearcoat :cry
Old Jul 28, 2003 | 07:35 AM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
Default Re: Need Help! (MilYellow02)
I you are yrying to remove the stain, do as MilYellow02 said. I have had this problem on 2 Jimmy's(95 &98) I have owned it the past. To get rid of them I had to use 3M Finesse II followed by 3M Swirl Mark Remover with my Porter Cable 7424 polisher.
To Need Help!
