Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
ZAINO TIME LIMITATIONS
Old Jul 30, 2003 | 12:05 AM
Anthony R. Laudicina's Avatar
Default ZAINO TIME LIMITATIONS
I'm running out of day light and weekend time to add to my 3 coats of Z5. Can I add a coat of Z5 at night in my garage and leave it to dry, then when I get home the next day take that coat off and Z6 it?Is 24 hours to much time to leave Zaino on with out buffing it off? This step will also save me from using my ZFX. I did use the ZFX in my first 3 coats. Appreciate your help.
Tony
Old Jul 30, 2003 | 01:15 AM
painexpert's Avatar
painexpert
Default Re: ZAINO TIME LIMITATIONS (Anthony R. Laudicina)
You can leave the Z5 on overnight without a problem.
Old Jul 30, 2003 | 04:24 AM
WWK888's Avatar
WWK888
Default Re: ZAINO TIME LIMITATIONS (painexpert)
Just be sure your car doesn't get dusty before you wipe it off or it may leave swirls.
Old Jul 30, 2003 | 08:03 AM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
Default Re: ZAINO TIME LIMITATIONS (WWK888)
:iagree: As long as dust and debeis did not collect on the surface overnight, you should be OK. Mixing ZFX with the Z5 also drastically reduces curing time. Depending on humidity, you can usually begin removing the polish within a half hour to hour of application. Just and idea if you run short on time.
Old Jul 30, 2003 | 05:35 PM
DsC5's Avatar
DsC5
Default Re: ZAINO TIME LIMITATIONS (Silver2002)
:iagree: I have left it on the wheels for over 3 days and it wiped right off.
Old Aug 1, 2003 | 12:46 PM
Kevin V's Avatar
Kevin V
Default Re: ZAINO TIME LIMITATIONS (DsC5)
There was a guy who stored his car during the winter and would leave a heavy coat of Z-5 on the car and remove it when he took it out of storage in the spring.
Old Aug 2, 2003 | 12:57 AM
Default Re: ZAINO TIME LIMITATIONS (Kevin V)
Thank you for all your responses. The info is appreciated.
Tony
[Modified by Anthony R. Laudicina, 5:58 AM 8/2/2003]
[Modified by Anthony R. Laudicina, 6:03 AM 8/2/2003]
To ZAINO TIME LIMITATIONS
