Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Porter Cable Buffer Recommendation
Old May 18, 2004 | 08:53 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Porter Cable Buffer Recommendation
So, i'm delving into the world of buffers, and need some help!
Basically, I'm a newbie when it comes to these things!!!
What model PC would you guys recommend for a newbie?
Also, i'm reading this stuff about backing plate and counterweights. I'm clueless on this. ANy insight on what this is all about and importance....and why isnt it sold with the buffer?? :crazy:
Thanks to all who chime in!!! :thumbs:
Old May 18, 2004 | 10:11 PM
ZOsix's Avatar
ZOsix
Default Re: Porter Cable Buffer Recommendation (y2k02c5)
With help from the forum I went with the porter cable from costal tool. http://www.coastaltool.com/cgi-bin/S...42f+1080677760
And Lake Country 71/2 "pads from Top of the line http://www.topoftheline.com/7durvelpad.html
:yesnod:
Old May 18, 2004 | 10:17 PM
DsC5's Avatar
DsC5
Default Re: Porter Cable Buffer Recommendation (ZOsix)
I'll second the 7424 recommendation. I use the 6 inch pads instead of 7.5 though.
Old May 18, 2004 | 10:52 PM
YLWFVR75's Avatar
YLWFVR75
Default Re: Porter Cable Buffer Recommendation (DsC5)
Can anyone comment on the counterweights and backing plate info....
thanks...or point me to a link that explains this
Old May 19, 2004 | 04:01 AM
TLL's Avatar
TLL
Bottom line 7336 just because to get a sanding plate for a couple extra bucks.
Get a 5" Professional backing plate hook and loop. Avoid the Meguiars plate the velco has very little bite and will allow the pad to move around exposing the plate.
Only use 6" pads. The weights are designed specifically for this diameter. If you use a larger pad it will adversly affect the performance. I got this from dealing with the engineers at Porter Cable.
I also like there newer 7424 buffer because of the ergo handle and light weight. I dont care much for the slow start feature however.
Porter Cable customer service can be a horrible but there equipment is very good. I
Old May 19, 2004 | 03:37 PM
6SpeedBowtie's Avatar
6SpeedBowtie
St. Jude Donor '08-'09
I agree.
I just bought the 7424 with bonus kit from Coastal tool. $119 and it includes a hook and loop (velcro) backing plate and the 6" counter weight along with the 5" counter weight that comes with the machine.
I then went to CMA ( www.properautocare.com) and purchased two each of the yellow and white polishing pads ($8.95 each). The yellow will give some medium-cut action and the white a mild cut. I plan to finish each detail with a hand application of my favorite polish (I'm still experimenting here), so I didn't opt for a finishing pad.
some additional information for your curiosity -- http://bimmer.roadfly.org/bmw/forums...1430487&page=1
I haven't had the chance to use the PC yet -- and you'd better believe I'm itching to get to it -- but my initial impressions are that I made a good decision here.
Hope this helps.
Old May 19, 2004 | 04:13 PM
Intermezzo's Avatar
Intermezzo
Default Re: Porter Cable Buffer Recommendation (6SpeedBowtie)
As much as I like the PC, my recommendation would be to get the Cyclo Polisher.
To Porter Cable Buffer Recommendation
