Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
How Do I Switch??
Old Nov 28, 2004 | 10:40 PM
JPatrick's Avatar
JPatrick
Default How Do I Switch??
After reading many positives about NXT, I'm ready to give it a try.
I've used Zaino for about a year and a half with good results on all three of my rides, but if I can save a few bucks, buy it locally and get results from NXT I'm in.
Question is- - - I've got several coats of Zaino now, what if any prep do I need to do to try the NXT?
Old Nov 28, 2004 | 11:46 PM
ZaneO's Avatar
ZaneO
NXT has some cleaners and abrasives in it, so if you haven't applied Zaino in quite a while, it may remove the rest.
*I* would probably use a light polish (Klasse AIO or Menzerna FP) or use something like 3M Wax and Adhesive Remover or 70/30 Alcohol/Water. AIO would most likely leave more protection than NXT, so you might not get a very valid durability test.
Old Dec 2, 2004 | 05:19 PM
Elpelon's Avatar
Elpelon
Before switching to NXT read the back label warning about getting it on plastic moldings etc. If it follows the usual pattern for these warnings then you might start to see white streaking on body moldings that get the wax on it.
Does Zaino warn about application to plastic moldings?
To How Do I Switch??
