Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Window Cleaning - Help.
Old Dec 19, 2004 | 06:43 PM
Old Lt's Avatar
Old Lt
Default Window Cleaning - Help.
The windows on my 2000 convertible have an oily film on the outside and inside. I can't seem to get them clean. I've used most of the over-the-counter products and nothing seems to cut the film. I even used a compination of water and ammonia and dried with newspaper, but to no avail. Does anyone have any suggestions?
Thanks,
151
Old Dec 19, 2004 | 06:53 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I've been using Rain-X glass cleaner..give it a try
Old Dec 19, 2004 | 06:58 PM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
Although I've read some critical things about this product in the forum, I've been using Stoner's "Invisible Glass" and have had very good results.
Old Dec 19, 2004 | 07:12 PM
GS Diva's Avatar
GS Diva
I don't know what "critical things" can be said about Invisible Glass. I've been using it for a long time...around the house, as well as on all cars...and think it's the best! We use it so much we order by the case!
Elaine
Old Dec 19, 2004 | 07:17 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I use Stoner's Invisible Glass all the time and love it.
But if you have an oily film on your glass you might try using Dawn dishwashing detergent to cut the oil. Of course that will also tax the wax off your car, too, so be careful.
Another thought might be vinegar and water.
If none of those work then try scotch and water. It won't clean your windshield, but you won't care any more either.
Old Dec 19, 2004 | 07:19 PM
GrayC5's Avatar
GrayC5
There has been quite a bit of discussion on this in the past in the Car Care Products section of the Forum. You might check over there. Good luck!
Old Dec 19, 2004 | 07:27 PM
NoelsTorchredZ's Avatar
NoelsTorchredZ
Another happy Stoners customer here! The trick is to use one micro fiber towel to clean, and a bone dry clean one to buff.
Old Dec 19, 2004 | 07:32 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I use Stoner's with newspaper, and buff with microfiber.
Old Dec 19, 2004 | 07:43 PM
Pumba's Avatar
Pumba
Lt,
I spent a year using Stoner's Invisible Glass and I was never able to get a streak free glass that lasted more than a few days.
I have changed over to Eagle 20 - 20 glass cleaner in the past 5 months and I am pleased with the results.
Good luck with your decision..
Merry Christmas everyone.
Old Dec 19, 2004 | 08:18 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I've heard good things about the Stoners. In the meantime, a microfiber and some Isopropyl alcohol will remove the film.
Paul
Old Dec 19, 2004 | 10:20 PM
jerseynick's Avatar
jerseynick
Stoner glass cleaner. It will come out super clear
Old Dec 19, 2004 | 10:44 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I had a film that just wouldn't quite and vinegar and water did the trick. Don't forget to do the inside too.
Old Dec 19, 2004 | 11:21 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Looks like I'm going against the tide here, but I never had good luck with Stoners. Maybe we have a resistant grade of road grime here, but it never got my windows completely clean.
I use spray Dirtex now, available at Home Depot.
It cleans well with one application, and no streaks. It has ammonia in it though, so it may not be safe to use on all window tint films (no problem with my Quantum tint).
Old Dec 19, 2004 | 11:23 PM
MY1STPEWTER's Avatar
MY1STPEWTER
I had some reading glasses once that were spotted like someone had been welding with them. Tried everything to clean them and nothing worked. Took them to eye doctor, they sprayed and wiped with paper towell and they looked like brand new. 4 parts water 1 part alcohol.
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Use just plain water and a Micro fiber towel and it will all be good.
Old Dec 19, 2004 | 11:26 PM
VETFVER's Avatar
VETFVER
I'm a Invisable Glass user but you might try Goo Gone. It won't hurt the glass and takes most everything off.
Good Luck,
Dan
Old Dec 20, 2004 | 01:16 PM
hltambur's Avatar
hltambur
[QUOTE=CAJUNY2KC5]I use Stoner's Invisible Glass all the time and love it.QUOTE]
To Window Cleaning - Help.
Old Dec 20, 2004 | 01:23 PM
I use Stoner's Invisible glass and it works very well.
Old Dec 20, 2004 | 01:25 PM
Gray Ghost's Avatar
Gray Ghost
That's the way I do it
Old Dec 20, 2004 | 01:28 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
