Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
shift lights?
Old Feb 10, 2005 | 10:09 PM
isosceles's Avatar
isosceles
Default shift lights?
What shift lights are you guys using? Is anyone using one with the factory electric tach and an MSD box? There is only one tach output on the MSD box, can I piggyback the tach and the shiftlight off the same terminal?
Anyone have pics of their install?
Thanks,
Old Feb 11, 2005 | 01:29 AM
LOTAHP's Avatar
LOTAHP
Mark, the Auto Meter seems to work fine. Nothing complicated about it. Don't remember EXACTLY what wires go where, but it took no-time to hook it up. Directions are very simple.
Old Feb 11, 2005 | 08:32 AM
Paul_Z06's Avatar
Paul_Z06
I (and a lot of C5 and Viper guys) use Raptor. I like it becasue it's small so you can squeeze it into more places. LEDs are bright.
Old Feb 13, 2005 | 06:34 PM
Special K's Avatar
Special K
Thanks,
OK, I know I'm going to get laughed out of here, but I use the one that came in the car. It's in the HUD. Works fine for me.
Old Feb 16, 2005 | 11:12 PM
InSaNeKaMeL's Avatar
InSaNeKaMeL
It's ok so do I, never raced on a track but it works good on the street
Old Feb 17, 2005 | 08:04 AM
Mitch C's Avatar
Mitch C
Old Feb 17, 2005 | 01:27 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I like the bigger ones like the Autometers, I had a smaller light built into the tach and I would miss it just not bright enough
Old Feb 17, 2005 | 04:11 PM
73jst4fun's Avatar
73jst4fun
Paulz06, who makes the Raptor shift light, is that available through Summit, Jegs..... do you have any pics of the unit?, uses shift pills or does it have adjustable shift points....Thanks
Old Feb 17, 2005 | 04:34 PM
ROJO99's Avatar
ROJO99
Raptor here, . Here is a link
http://www.raptorperformance.com/
Adjustable, easy mount have mine attached by twi sided tape on the A pillar, sleek...
The system adjust be two small radial dials in the side cylidrical face. One switch for 1000's and one for 100's if I remember correctly. I have not adjust mine in 9 months. Just need to remember to carry a very small flat head screw driver.
Old Feb 17, 2005 | 05:22 PM
Paul_Z06's Avatar
Paul_Z06
There ya go. No pills, easy setup, good instructions, very easy to change rpm settings.
Old Feb 17, 2005 | 06:25 PM
73jst4fun's Avatar
73jst4fun
Thanks guys, I'm currently using the Autometer shift light and would like to use a smaller unit, this one sounds like the way to go....
Old Feb 17, 2005 | 06:50 PM
69ttop502's Avatar
69ttop502
Can the Raptor run off the tach output of an MSD without an adaptor?
Old Feb 17, 2005 | 08:44 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
check out the harlan shift light as well
http://www.harlan-engineering.com/st...hiftlight.html
Old Feb 18, 2005 | 01:18 PM
ROJO99's Avatar
ROJO99
Yes. That is how I wired my unit.
Old Feb 19, 2005 | 03:35 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I have the raptor installed in my duel gauge pod.
To shift lights?
