Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
will this work?
Old Jun 22, 2005 | 10:38 AM
f355c5's Avatar
f355c5
Default will this work?
I have a C6 w/Automatic Trans. Z51 . If I leave the line w/tc on and turn it off 1 second or so after I hook up. 391 rwh can"t hook up until
2nd. I am talking about only Traction control at launch. Hope you understand my problem
Old Jun 22, 2005 | 10:46 AM
C5 CU's Avatar
C5 CU
I tried that method when I had an A4 C5 Coupe, but never worked as well as just getting accustomed to "feel" of gas peddle. TC off, launch at highest rpm w/o excessive spinning and feather in or just launch some feather and then hit....both seemed to work mostly dependent on track conditions which worked best....good luck.
Old Jun 22, 2005 | 03:23 PM
f355c5's Avatar
f355c5
Thanks for your reply. Forgot to tell you I have a 2800 stall converter and was hoping the tc trick would work. Raining every day so /won't be at the track any time soon
Old Jun 22, 2005 | 05:42 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Are you running street tires or drag radials?
Old Jun 22, 2005 | 05:57 PM
f355c5's Avatar
f355c5
Run flats
Old Jun 22, 2005 | 06:09 PM
jpee's Avatar
jpee
Originally Posted by f355c5
Run flats
Forgetaboutit...You will NEVER get consistent launches with those tires.. if you only play at the strip 1 or 2 times a year.. live with it..
However if you are even "Semi Serious" about drag racing get a set of Drag Radials..
Old Jun 22, 2005 | 06:46 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Drag Radials or ET Streets are the way to go.
Bob
Old Jun 22, 2005 | 11:13 PM
f355c5's Avatar
f355c5
thanks.
To will this work?
