Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Spring setup for drag racing?
Old Nov 26, 2005 | 11:48 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Spring setup for drag racing?
By no means am I a drag racing setup expert, so I'll ask you guys.
In general, if I'm going to set-up a car (any generic RWD car) for drag racing, what would I want to change spring-wise from stock....and WHY?
Would I want stiffer front and stiffer rear, but the same proportion of rates?
A lot stiffer in the front and a little stiffer in the rear? vice versa?
Softer in the front and stiffer in the rear?
etc....
Old Nov 27, 2005 | 12:50 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I think we would need some info about the car.
Old Nov 27, 2005 | 12:55 AM
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
For argument's sake, let's say it's something smaller than a Vette like a Miata or S2000 or Solstice, except with a 400hp V8 in it. 3300lb, slightly nose-heavy.
Old Nov 27, 2005 | 07:56 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Go with the softest front springs that you can find.. I personally have '65 Vette small block (no AC) front springs with Compretition Engineering adjustable Drag Shocks (set to 80/20 currently) (QA1's would be better but are a lot more $$$) and a 400 lbs/inch Rear spring with QA1 adjustable rear shocks.. (set to about 40/60).
That setup would help you to get some needed weight transfer and taking some of the punishment off the rear end (due to excessive squatting with the stock rear spring)
To Spring setup for drag racing?
