Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Just got a compressor...quick setup?
Old Jun 8, 2006 | 09:35 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Default Just got a compressor...quick setup?
Just got a Craftsman air compressor for my birthday this week from the family. It was unpacked Sunday but I did not have a chance to set it up and use it.
I took a quick look at the book and it is big.
Any quick start tips so I can get it going right away before i read the book?
Plans for it?
  1. Tires/wheels
  2. brakes
  3. blow off dust on the engine
  4. pool toys
Old Jun 8, 2006 | 09:46 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Happy Birthday....... Is it oil free? That you can just plug in, turn on and go. If it's not, check and fill oil as needed. Make sure the belt is on and adjusted and away you go. I'm sure you will find many uses for it.
Old Jun 8, 2006 | 10:08 PM
sixspdvet's Avatar
sixspdvet
Happy Birthday Edgar... Like above make sure the oil is ok.. Check the guards and make sure they are tight..
Fittings,, regulator,, make sure you have the power to run it.. if it's real big you might need 220 or at least a 20amp outlet.
Don't want you to burn down the garage...
Ernie
Old Jun 8, 2006 | 10:15 PM
Tony.96LT4's Avatar
Tony.96LT4
Ah, air tools!! Lets see air ratchet 3/8". grease gun, air chuck(don't get the one that sears sells that's plastic, it fell and broke before I had a chance to use it.) Die grinder, air drill, 1/2" impact gun, paint gun, sand blaster, etc. If it's oil free then put the wheels on that baby and as 16 again said, fire it up!
mowton's Avatar
mowton
Edgar, congrats on the new compressor and Happy Birthday
The only thing I had to do on my Craftsman Compressor was to open the petcock at the bottom of the tank and run it for 10 or 15 minutes (can't remember). It's just to clear any condensation/moisture before you hook up you tools.
See ya sunday at E-Town?
Ed
Old Jun 8, 2006 | 10:21 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
it is this baby right here and oil free
comes with gun and ratchet but does not look like it comes with sockets.
Tony what is is an air chuck
Old Jun 8, 2006 | 10:25 PM
16Again's Avatar
16Again
Air chuck is used to put air into your tires.
Old Jun 8, 2006 | 10:41 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
looking at the accesories kit it appears there is a "chuck" there
Old Jun 9, 2006 | 04:32 AM
_twisted_'s Avatar
_twisted_
thats the fathers day gift
Old Jun 9, 2006 | 07:23 AM
BlackC6LS3's Avatar
BlackC6LS3
Old Jun 9, 2006 | 12:26 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
Plans for it?
  1. Tires/wheels
  2. brakes
  4. pool toys
Most air compressors require that you run them for 30 minutes with the valve open to break in the motor and parts.
Old Jun 9, 2006 | 04:18 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Damn Rob you ruined my fun...now i have to read the book first
won't be home till midnight tonight....wait for the explosion tomorrow around noon
Old Jun 9, 2006 | 07:07 PM
_twisted_'s Avatar
_twisted_
makle sure you take notes, I wont get mine until next week.
And a belated Happy Birthday
Old Jun 10, 2006 | 12:04 AM
98NYFINESTVETTE
Well, The compressor will not explode - It will just stop working while popping the breaker. I know. I was at my friends house and he did this. I read the instructions while he was trying to why the fuse would keep tripping. After the 4th time he decided to listen to me and the compressor has been working great since then. We sell Michelin air compressors. So far I have not seen any returns on them. They are also inexspensive. They will run any air tool you have and the compressor does not take up to much space.
Old Jun 10, 2006 | 12:08 AM
comp's Avatar
comp
have the same one opened drain and ran 5 min. reset presure th 80 pounds and let it cycle a few time's
happy B-day late
Old Jun 10, 2006 | 08:03 AM
onefast99's Avatar
onefast99
happy B-day late
The one i have is the model before this one, I didnt get all the tools you have just a few. Let it run for 30 minutes and then use the air piece to blow away some dust and debris you may have lying around(test phase). After that you can do anything you want with it, the air gun is perfect for getting the tires on and off especially to clean all the rubber under the car. Enjoy it and remember anything that goes wrong with it bring it right back for a new one....
Old Jun 10, 2006 | 09:19 AM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
JD, you were early not late with my birthday wish...thanks again.
Okay, all rolling...first impressions...
  • yes the instructions said to run it with the valve on the bottom open for 15 minutes. Problem....might be me, but the instructions said open is counter clockwise....it is NOT. Counterclockwise brings the thingy down and closes it. How do I know, it shut off after building pressure during this break in period so I spun the other way and out comes the air..
  • funny how it brings 3 male disconnects but 4 tools that need them
  • don't understand the inflator/deflator tool...actually only how the deflator works
  • inflator deflator tool has a ring I don't know what it's for
  • impact gun said to oil but not sure where...on the right side it says oil but looks to be closed, on the left side there appears to be a hole for oil
  • the thing will do like 140 psi but the tools all say 90 psi, what will need more than 90? Painting?
  • this thing is heavy...not sure how my girls got it in the garage
  • waiting for my first pool toy fill up
  • will do tires later
To Just got a compressor...quick setup?
Old Jun 10, 2006 | 11:20 AM
ralph's Avatar
ralph
Does Carmen know you have this. You're gonna be more dangerous than ever
Enjoy & happy birthday
Old Jun 10, 2006 | 12:00 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
okay here are some more lessons learned.
I got new tires on the truck recently. I have not had a chance to check the torque on the nuts though I know they must be over torqued.
Got to one front wheel and one nut would not come off at full power of the gun. Went for the breaker bar (Ralph do you have it?) and could not find it so used the torque wrench. It came off pretty easy. Does this mean the impact gun is not very powerful?
Lesson two....regular sockets will not survive in the impact gun in that case is it got chipped inside. Guess I have to buy impact sockets for the wheels...hate it when a new toy forcess additional purchases.
Old Jun 10, 2006 | 12:34 PM
16Again's Avatar
16Again
Edgar, typically the tools that come with the compressor are junk. I still have all my originals that you can have should you desire some more junk. Go get yourself a good 1/2" impact gun, Ingressoll Rand makes some nice stuff. You also will need IMPACT sockets to use with the IMPACT gun. Notice how that works. NEVER use a torque wrench to loosen bolts You might need to replace that now as well. 140 psi would be for a sander, usually they use more pressure.
