Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Question Regarding Shifting
Old Sep 21, 2006 | 08:03 AM
CamaroCane's Avatar
CamaroCane
Default Question Regarding Shifting
OK, so im new to this dragracing stuff.
I dynoed my car and made max HP @ 5850 RPM now my car redlines at 6500, should I shift 5800 or wait till 6500?
Old Sep 21, 2006 | 09:32 AM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I'm thinking you should shift as close to redline as possible, without hitting the rev limiter.
Old Sep 25, 2006 | 10:16 PM
shurite44's Avatar
shurite44
That works good for me in C5's and C6's.
It is not just the HP at the RPM in the gear you are shifting out of, you also need to consider what RPM you will be at when you engage the higher gear.
The closer to 6500 you get without hitting the rev limiter means you will be that much higher rpm after you shift.
Old Oct 5, 2006 | 12:02 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I'm no expert but I don't think you just want to forego that last 700+ RPMs. As was mentioned, you want your RPMs up for your next gear and I would think you should still have some pull all the way to your shiftpoint.
My engine redlines at 6800 RPMs....I've been trying to shift at about 6500-6600 RPMs. You certainly don't want to hit the rev limiter but I think you want to 'approach' it.
Old Oct 6, 2006 | 02:32 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed you want to pull as long as possible but, with a 6.5k RPM redline and no shift light, you should likely target say 6.2k-6.3k RPM at least for the 1-2 shift.
Old Oct 6, 2006 | 08:43 AM
Ranger's Avatar
Ranger
There are two ways to determine optimal shift points.
(1) experimentation
(2) calculation
On a stock LS1/2/6/7, owners have been experimenting since CY 1996 and generally found that shifting right before the limiter brought best acceleration.
You can do the calculation of ideal shift points if you're curious or your car has significant mods. To do this you need to know your tranny ratios, your rwhp at 100 rpm increments between say 4400 rpm and the limiter setting (from a dyno run output in plain values rather than plotted on a curve).
Then you go to this shift point caculation guide
Ranger
To Question Regarding Shifting
