Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Shock absorber question
Old Nov 16, 2006 | 06:08 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Default Shock absorber question
My car has the F45 suspension and I'm considering changing to different shocks. What type of shocks should I be looking at for straight line performance? I only have 21,000 miles on my car, which creates another question. Does age have a negative affect on shocks? Am I better off staying with the stock shocks?
Old Nov 16, 2006 | 07:11 PM
ralph's Avatar
ralph
For drag racing you're probably better off with worn out shocks as long as you're not getting wheel hop. If you are going to buy new shocks, consider adjustables. then you can tune for the track and for the street or road course or for autocross if so desired.
Old Nov 16, 2006 | 07:21 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Yup worn shock work better.
If you are going to do it a lot and visit various tracks you can consider adjustable shocks which would be best of all worlds but pricey
Old Nov 16, 2006 | 07:36 PM
Brandon Terry's Avatar
Brandon Terry
Cruising
If Qa1 makes adjustable shocks for your car you can get the best of both worlds(racing & cruising). I run the single adjustables
Old Nov 16, 2006 | 09:14 PM
BERGN8R's Avatar
BERGN8R
I removed my F45 set up late this summer. I just went with Bilsteins but would suggest the QA1 adjustables.
FYI the trick to removing the RTD from the computer system is finding someone with a GM Tech II programming unit to remove the option and disconnecting both cables from the module in the left rear hatch area and then cycling the battery. I read a lot of threads discussing how to do this but cooudn't get it turned off until cycled the power with the cable disconnected. You don't need simulators and I even removed the switch because I happen to have another panel without it.
To Shock absorber question
