Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Solid axle rear question
Old Dec 5, 2006 | 11:50 AM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Default Solid axle rear question
A few questions for those running a solid axle rear end in a strickly drag car:
1. Is there a minimum (or optimim) amount of vertical movement that a solid axle should have?
2. Is more vertical movement better?
3. Do you use snubbers or some other restricting device to limit the amount of travel?
Thanks,
Charles
Old Dec 5, 2006 | 05:05 PM
Glensgages's Avatar
Glensgages
You might have better-luck looking here:
http://drr.infopop.cc/eve/forums/a/frm/f/80760912
Old Dec 5, 2006 | 07:31 PM
Hurri's Avatar
Hurri
Default rearend
Thanks,
Charles
Charles,
I've got about an inch travel compression and about three inches "lift" travel
I have to use the stock spring. It's not a 4 link.
To Solid axle rear question
