2 Step users step in please...
Aug 18, 2007 | 04:19 PM
St. Jude Donor '06
What RPM have you set for launch. The unit i have is set from the factory at 2500 rpm. I am all motor off launch. Thanks
Aug 18, 2007 | 06:30 PM
Cruise-In II Veteran
Cruise-In III Veteran
Mine is tied into the trans-brake and it's fully adjustable in 100 rpm increments. I usually start at 2800 and work up depending on track conditions and how much stress I'm willing to put on the differential.
Aug 18, 2007 | 09:42 PM
St. Jude Donor '06
Aug 18, 2007 | 09:45 PM
I have it set for 3500...
Aug 18, 2007 | 09:55 PM
Just wondering, what stall do you guys have.
I try to take it nice and easy on my drivetrain to make it last. lol
I'm set at 3500, stall is 4000.
But I weigh a lot less than most of your cars so don't judge by mine.
Aug 19, 2007 | 11:00 AM
stampede3,
My new setup uses a custom converter built by Coan (4200 stall). They used data from my dyno runs and how I use the nitrous to come up with the best design.
Aug 19, 2007 | 01:07 PM
What brand two step is everyone using?
Aug 19, 2007 | 03:12 PM
AST-1 made by Synergy Motorsports:
http://www.synergymotorsports.net/
Aug 19, 2007 | 05:48 PM
Quote:
Originally Posted by
billiardcue
One of the only ones around here useing the holley annihilator ignition system.
I control everything from the key pad in the cockpit.
Burnout RPM
Rev limiter
Shift point rpm
Launch limiter
timing curve.
While I would heve prefered MSD I got a good deal on it so figured I'd try it.
Aug 19, 2007 | 11:08 PM
BigStuff3. Set at 5000 rpm.
