Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
13s?
Old Feb 14, 2008 | 01:52 AM
2005avtj's Avatar
2005avtj
Default 13s?
I just bought a 84 auto vette with the crossfire and I was wondering what would it take for me to reach mid to hi 13s...I am converting the crossfire to carb...I would like to reach the 13s on street tires...any suggestions guys?
Old Feb 14, 2008 | 07:28 AM
Glensgages's Avatar
Glensgages
The Cross-Fire in my '82 is 9:1 from the factory (and I assume that yours is also ) with the junk 76cc heads:
a switch to 64cc heads will raise that to approx 10.2:1, if you run a good grade (93 octane ) gasoline.
Other typical small-block Chevy mods will work (camshaft, headers & exhuast, etc. ) along with your carb/intake swap:
I believe the pre-'87 style 700R4 transmissions are very-weak (mine failed behind a stock Cease-Fire ), so you want to consider an alternative (older-style THM400 of 200-4R ), and you'll probably want to change your rear-gear ratio into the 3.55/3.73 range (mine was 2.87 stock ).
Old Feb 14, 2008 | 11:56 AM
CFI-EFI's Avatar
CFI-EFI
Or for a total investment of less than $1500.00 you can leave the carb where it belongs and work with your Crossfire.
RACE ON!!!
Old Feb 14, 2008 | 06:12 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Just put some headers and pipes on it,converter and you should hit 13's
Old Feb 14, 2008 | 07:00 PM
2005avtj's Avatar
2005avtj
Headers, full piping, and converter doesn’t sound so bad… I just want enough HP that I can run 13’s consistently…plus I never had a fast car, so this vette may do it for me…thanks guys for the info… anything else I can do to get me in the 13’s with out force induction
Old Feb 14, 2008 | 07:18 PM
eddie the kid's Avatar
eddie the kid
gut the cats out.
Old Feb 14, 2008 | 07:48 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Port your intake. Not only is it by far, the single best bang-for-the-buck mod you can do to a CFI motor, but it's also the single biggest/best mod you can do (Power adder excluded) to a CFI motor.
Old Feb 15, 2008 | 02:21 PM
2005avtj's Avatar
2005avtj
Originally Posted by eddie the kid
gut the cats out.
cats? i think i only have one...how many cats should be on the car i read somewhere that it should have 3?
Old Feb 17, 2008 | 03:38 PM
WEB AIR's Avatar
WEB AIR
Try two poodles!
Old Feb 19, 2008 | 12:42 AM
2005avtj's Avatar
2005avtj
lol i wouldnt know what to do if i found 2 poodles
Old Feb 19, 2008 | 10:28 AM
CFI-EFI's Avatar
CFI-EFI
gut the cats out.
Another ***** posting where he has no idea of what he's talking about. The 1984 and 1985 have but one catalytic converter. If the cat is in good condition, gutting or removal will provide little benefit.
RACE ON!!!
To 13s?
