Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Converter efficiency
Old May 27, 2008 | 07:05 AM
Vesa's Avatar
Vesa
Default Converter efficiency
Anybody having tried different ATF to get different slippage/efficiency out of the driveline? And would the different viscosity also effect the stall rpm slightly?
Was thinking of if there is a practical difference using RedLine Synthetic ATF vs RedLine Synthetic High-Temp ATF.
http://www.redlineoil.com/pdf/3.pdf
This crossed my mind after I found this text on web
Efficiency
h (m) = is P(out)/P(in). This is a function of fluid viscosity, fin design in the turbine and impeller units, T(out), T(in) and other variables. Torque converters run at efficiencies anywhere from 0-95% depending on w(in), w(out), and T(in) and T(out). For example, when a car is stopped at a traffic light, the engine still applies power to the input shaft, but the brakes and transmission prevent the output shaft from rotating. Since P(out) = T(out) * w(out), and w(out) equals zero, P(out) equals zero. Therefore, the efficiency equals zero.
When a car is traveling at highway speeds, the turbine is rotating nearly as fast as the impeller. Recalling that they are attached to the output shaft and the input shaft respectfully, then P(in) » P(out) and therefore efficiency is rather high.
Old May 27, 2008 | 12:43 PM
Vesa's Avatar
Vesa
Where are the converter gurus
