Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
2 step, rev limiter
Old Oct 23, 2008 | 02:25 AM
dmaaero's Avatar
dmaaero
Default 2 step, rev limiter
Where are you wireing your stutter box to on a 4 speed car? If your using a button on your shifter, can you point me in the direction of a good button? Thanks david
Old Oct 23, 2008 | 11:11 AM
Ksths2's Avatar
Ksths2
not trying to hijack the thread but i'm also curius what 2 step can be used with the stock computer on a 02 C5?
Old Oct 23, 2008 | 11:41 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
On the c5, while not truely a two step, lingenfelter sells a launch control that is used like a two step. It just does not have the top end rev limiter since your computer has that
Old Oct 23, 2008 | 01:16 PM
Ksths2's Avatar
Ksths2
REGAR, Thats exactly what i'm looking for Thanks a ton! - i just realized that i emailed you the other day about your setup and steering me in the right direction as far as heads.
Old Nov 12, 2008 | 07:44 PM
Blacisi's Avatar
Blacisi
Mine is wired to a master switch and then thru the clutch switch for activation.
To 2 step, rev limiter
