Finally, 11s :-)
http://www.angelsghosts.com/how_to_g...of_ghosts.html
Once you "rescue" your ghost, times falling below 11.00 will easily come to you at -2000 to -3500 DA at Atco!
I think that question is best left to your tuner at Cartek? Sounds to me the answer could be something in your tune. I did notice when I went from my track at +800DA and went with the same tune to MIR at -1521 DA, that I got a lot of KR from 2-20mph which I never had before. It definately was due to the lower DA. So your tune can be definately affected by DA. Are you data scanning and logging your runs while making your 1/4 mile runs?
home for the strip without my laptop and HP Tuner.
I hope it can be figured out. I want those 2 tenths.
You are talking about a +1000 DA diff from your claimed -800. This would equate to a rise of about +12 degree ambient at Atco which according to every online station, never happened. Whatever you may say, I'll never believe it.
At no point at that track on that day was it EVER -1800 or -1900 and whatever YOU may say, I'LL never believe it BECAUSE I WAS THERE with three separate handheld weather stations at my disposal.
You don't have to believe me but why are you refusing to believe any of the weather stations we had at the track?
Based on that logic, if our weather stations aren't accurate then neither is yours.
Which do you think is lying, the ones at the actual track where the cars are physically racing or the ones that are gathering info from some general source nearby and conveying those general parameters to 2nd and 3rd party websites?
Perhaps MIR (or your home track) has it's own weather station right at the track where the online sites are getting their info from, hence why your handheld corresponds with it?
Atco is a small backwoods little town and has nothing like that anywhere within many miles of the actual track so any info of that nature obtained online cannot possibly be 100% accurate.
Yes, actual readings at the track can in fact be 1000 feet (usually closer to a 600 foot difference) off of the online sources.
They're often blessed with air as good (or better) than the Northeast and they're also still open during those times to boot.
I'm surprised, most REAL drag racers already know this.
that is true! cold temps and 30.50+ and low elevation
and its not the da at atco cars run great there year round, its all the fresh air its in the middle of the pine barrens the Wharton state forest surrounded by cranberries and blue berries, no weather stations close. the best thing to do is put a few pine tree air fresheners in your filter
Uh, Is that why REAL Drag Racers from Houston want to go to ATCO and not the opposite? How come I never hear of you guys wishing and wanting to go to MIR or Houston or wherever to go find better DA. Duh. ATCO Is The Place To Be For The Lowest DA Almost Everyday!
True, also away from the heat of the motor/exhaust and sun beating on the car's paint as well.That's exactly how the veteran racers I hang with at the track use theirs as well.
Though, if you're racing on a sunny day and that sun is beating on the black pavement with the air that enters your motor coming off of that hot pavement, is the weather station's reading that was derived from in the shade truly accurate either?
Mine doesn't.
And is this tripod at bumper/air filter height? Any higher or lower and it is, once again, not entirely accurate.
But it's certainly close enough.
Getting handheld weather station DA readings from incoming engine air coming off the pavement into the filter is totally useless and irrelevant to this discussion. For that, you need to data log your IAT's etc. to make that air info relevant to your car's performance. You are confusing the general DA readings of the air surrounding your vehicle when stationary as opposed to the measurement of air entering your vehicle while moving. You need a data logger for that info, not a handheld weather station which gives general outside track air information. Any REAL racer should know that
Thank you for helping prove my point.
