ECS Hardcore Drag Parts: Not for the faint of heart.
#41
Hey Doug. You guys have worked on my C5Z a bunch of times
I currently have VBP poly bushings and LG coilovers/Pfadt street sways on my road car, but the creaking from the rear is way to much for me. It drives me mental. Would installing the Pfadt Spherical Bearing Kit help?
#42
However it may not be the poly bushings creaking, it could be the sway bar bushings. Did you disconect the sway bar to rule that out?
#43
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
I am going to install mine soon, so I will let you know what the ET differences are.
Thanks.
#44
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Doug,
Congrats on the LSX true street win!!
This is obviously a testament to the quality products you guys develop and sell - and the great work you guys do at the shop.
#45
The sway bars are pretty new and were a replacement for T1s. What I'll do is have you guys look at it when I bring it up there for a new diff.
#52
Question on the torque tube safety strap. Does it add a lot of vibration or noise ? Thinking this would be a good add on for street driven car too, to prevent drivetrain breakage.
#53
I'm sorry I did not respond to this earlier, I must have over looked your question. We have not noticed any drive line vibration from adding these, however the cars we have installed these in have Pfadt engine mounts already which increase the vibration in the car a little already so it's hard to say. Plus they are in the upper HP ranges, so the idle's are generally not like stock anyway.
We have a foam liner we have been installing on the brackets to eliminate the steel to aluminum contact, but I do not feel there would be an issue with vibration either way.
thanks
#54
thanks
thanks
Thanks Doug,
I did not think that their would be any added vibration especially since I added a much thicker tunnel plate to my car years ago. Long as it's not metal on Metal on the loop to the tube it should be quiet.
#55
For those who have been waiting patiently for your Power glide, they are here and getting final fitted with our brackets as I type!!
We had a delay from the shaft manufacturers that really held us up a fair amount, we sincerely apologies for the unexpected delay. So that will never happen to us again, we ordered-and received- a ton of them so we have them ready to go for both the C5, and C6Z configurations. We honestly did not expect to sell as many as we have, so we were purchasing them in smaller amounts, which put us on the back burner with the manufacturer I guess, even though we were promised much sooner.
The actual transmissions and our brackets are never more then a week out, so from now on we should literally be able to overnight a glide package the day it is ordered if necessary.
I'll post up some pics of the C6Z configuration shortly, but for those who have been waiting, expect a package at your door soon! The will be leaving here starting tomorrow.
Thanks, Doug
Thanks, Doug
#56
quick question.. with the pfadt drag coilovers.. How would they be on the street?? and would the car still handle well?? or will it be just basically for drag use only?.
