Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
10.65 @ 135.80mph
Old Jan 22, 2011 | 02:21 AM
winters97gt's Avatar
winters97gt
Default 10.65 @ 135.80mph
Got in the 10's!
Old Jan 22, 2011 | 08:19 AM
GARY2004Z06's Avatar
GARY2004Z06
Congrats. Very nice pass. The speed shows your potential for a high nine second run. The key will be in the sixty along with the seat time you had mentioned. You will need to replace that clutch to have any shot at this but I'm sure you know that.
Good luck.
Old Jan 22, 2011 | 09:04 AM
winters97gt
Good luck.
Thanks, Gary! Followed you guys for years. I probably read all of you and Rob's posts over the last 2 years.
The clutch is the ACT twin, and brand new. This was the first and only pass on it, since the ls7 would not let me do a burnout and launch(glazed over with 600hp). I'm just going to run the 1/8, since we have a good track here in houston. Once I get 10-20 passes with this clutch, I will take it back to RPR in Houston(old HRP) and go for a better ET. I don't get a warning, just the boot after 1 pass.
I feel that this clutch will allow me to go high 1.6's without risking the rear end, where the spec 3 would just bite hard, and I broke RPM rear ends with much less power.
What do you think about ls7 manifolds and the ZR1 cam? Looking at 10.3's on the stock motor, and keeping it quiet? England Green will custom spec a baby blower cam for me, but want to see what you all suggest. Fiancee will not allow a bigger cam. Thanks!
Mark
Old Jan 22, 2011 | 09:35 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
very nice pass. congrats on 10!
Old Jan 22, 2011 | 12:15 PM
LS1LT1's Avatar
LS1LT1
That's a strong running car especially with that sixty foot, has more in it for sure.
Old Jan 22, 2011 | 12:41 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Very Nice Mark!!
Old Jan 22, 2011 | 01:01 PM
GARY2004Z06
Mark
Sorry Mark, it was too early in the morning plus I was getting ready for my daughter's basketball game. I missed the whole clutch explanation. If you come out relatively soft and cut a high 1.6x, you should drop your ET by about 2 tenths. This would put you in the 10.4s. A slighly more aggressive launch to put you in the high 1.5x range could drop another 1 1/2 tenths. This should not overstress your rear depending on technique; however, the decision is yours. I will let the experts give you advice regarding the manifold and cam since I am unfamiliar with the FI setup.
Keep us posted on your progress.
Old Jan 22, 2011 | 01:53 PM
Vetter 1's Avatar
Vetter 1
Congrats! Very nice!
Old Jan 22, 2011 | 02:33 PM
J Z06's Avatar
J Z06
That is awesome!! Tell Stephen Jay from CT said Hi!
Nice numbers! There is more in it for sure. Awesome for a street car
Old Jan 22, 2011 | 04:33 PM
Rob Petyo's Avatar
Rob Petyo
nice numbers - congrats!
Old Jan 24, 2011 | 04:12 AM
winters97gt
Thanks guys! I was so happy after the pass. Figured I would have to give it a couple more trys.
Will do.
Thanks, Gary. Looks like I am going back to 1/8 racing for the next month or so. We have a decent 1/8 track here in Houston that has ok prep on Sundays. I'll work on running the car, especially the clutch slip and 60ft, since the 3/4 shift is not near as important to my ET right now.
Old Jan 24, 2011 | 07:56 AM
GARY2004Z06
Mark,
The 1/8 mile is a great idea. If you track all of your passes and put them on an Excel spreadsheet, you can predict your 1/4 mile ET by adding the calculated differences between the 1/8 and 1/4 of previous runs. The extra seat time will hone your skills.
Old Jan 24, 2011 | 09:34 AM
Kingsize's Avatar
Kingsize
Awesome! Just saw this thread... Glad you got it all sorted out Mark. Now it's just practice, practice, practice. Hope to see you around RPR again soon.
Old Jan 25, 2011 | 01:39 AM
winters97gt
Thanks! I want to watch the black beast run down the track. I'll see you out there soon.
Gary and everybody else. A few questions if you don't mind.
I see a bunch of you guys running GTO spares. What ET effect do you guys see? I always ran weld draglites on my mustangs and they were worth a solid .1-.2. I had a set of GTO spares for my Z06, but sold them, as I wasn't completely sure they were safe. Aren't the offsets slightly different? Did you guys grind the hub, or the wheel?
Cage recommendations? What does everybody run, and do you feel safe. My shop does their own custom welded in cages that are very nice, with removable bars, but not sure I want a weld in cage unless there is a difference in safety.
LS7 exhaust? Andbody have a guess on what power I would gain? I blew out the stock LS3 cats in just a couple thousand miles. I have new LS3 cats on, but they should be fried soon. I'll do headers if they are just a waste of money.
Thanks!
Old Jan 25, 2011 | 09:13 AM
GARY2004Z06
Thanks!
GTO spares are an economical way to gain about a tenth IMHO. No issues on our cars. We did switch the rubber over to M&H radials to make us feel safer although we did make numerous passes on the OEM spare tires. (I cannot advocate this do to their speed rating.) Recently switched the entire setup out for Bogarts with bias ply. We have not seen any gains from this over the GTOs but it is a more attractive.
I would strongly recommend getting a rollbar that fits exactly like you want it to. Whether it be off the self or custom. You must live with it. I have hit my elbow on some and have been cramped by others. Take your time before you make a decision.
LS7 manifolds are good, the cats have failed on me but we always end up swapping out to ARHs. Nick builds a great product.
Old Jan 26, 2011 | 01:17 PM
PRE-Z06's Avatar
PRE-Z06
Congrats again Mark, too bad you can't run up here as they're a little more lenient. Strong mph, skinnies and cam should put you over 140! Thought you wanted to keep the noise to a min, which is why I mentioned the ls7 manifolds with cats. Z51 trans gears would the help 60'...of course I know you haven't really launched the car yet
Old Jan 26, 2011 | 07:06 PM
winters97gt
Thanks Chris! Mike has some lying around at Gforce in Houston. I was going to pick them up, have Stephen at EG spec me a custom baby blower cam, or install a ZR1 cam, and do that. But after Gary, and my searching, it seems like it nots going to work FI. Seems they fail, too. This week, it looks like I'm just going to sit on it for a while, as I really don't want headers, but I might have to do it.
Yeah, 2800rpm is not really launching, but glad I got a solid pass in.
To 10.65 @ 135.80mph
Old Jan 26, 2011 | 08:18 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Nice going! There is more in it as she sits I bet with a better launch.
I'm just wondering why you backed back up into the water AFTER you drove through the water? I think you should go a bit slower through the water as well so you don't sling water up into any of the wheel wells, especially the fronts. Dragging water up to the starting line is not so good as you know...
Keep at it!
Ron
Old Jan 26, 2011 | 08:27 PM
LS1LT1's Avatar
LS1LT1
but I don't think he actually went entirely through the water the first time, he appears to actually go around it/past it at an angle and then backs in to it from what I can tell.
Old Jan 26, 2011 | 09:04 PM
winters97gt
Yes, I did go around the water. The waterbox sometimes is too big on street nights and there is no avoiding it completely, there was no standing water where I drove through.
