DR question ??
Don't worry about diameter. I'm just using these as an example for side wall comparison.
Thanks ...
I believe a lot of it will depend on the car's power level, type (NA, nitrous, blower etc.) of power and transmission (automatic or manual) of course but usually more sidewall is better as long as it also coincides with one's final gearing needs.
So we are talking about a 20lb difference to gain roughly 1" diameter of side wall. Basically 4.30" side wall to a 5" side wall for an additional 20lbs of rotating mass.
Which avenue is better ??
FYI, I'm '04 ZO6, 6 speed, 4.10, 3015lb with me, roughly 500rwhp N/A plus 150 shot.
Thanks....
Thanks..
But I think you mean 315-30-18s?
The one thing I noticed about side wall height is the effect on RT. If you are worried about RT, in my opinion, the taller Hoosiers (16 inch) really hurt RT. This is due to the very soft sidewall and the large amount of wrinkle that occurs on launch. I am sure others will disagree with me on this.
Also as far as the drag pak goes (weight savings, etc.) I basically feel going this route is a waste of money. Eric i think will agree with me on this. You gain very little for a lot of cash. With the drag pak I gained at best 0.04 sec in 1/4 mi ET. Not much. However I do like the look and the skinnies are great for keeping the car very straight on the big end.
The one thing I noticed about side wall height is the effect on RT. If you are worried about RT, in my opinion, the taller Hoosiers (16 inch) really hurt RT. This is due to the very soft sidewall and the large amount of wrinkle that occurs on launch. I am sure others will disagree with me on this....
A larger sidewall allows more adjustment of RT via rear tire pressure. I have found that 1lb of air pressure = .010 RT in my Hoosier QTP's vs 10 lbs air pressure = .010 RT in my 17" BFG drag radials.
Something for the bracket racers to think about.
I understand all the variables associated with this question but an educated guess would be appreciated.
Damn, when I go back and read want I wrote.... It sounds like a serious newbie question !! Haha !!
Anyways...thanks..
Anyways...thanks..
Thanks... McLeod RXT
What are your 60's now employing the ranger method?
-You can't go by auto's, they are different animals.
-Ranger's writeup will help everyone with a 6 speed but they are more for stock clutches.
You will need to develop a whole new launch style depending on power/clutch/track prep/tires.
So AFTER you choose the tires then we'll help dial you in with launch rpm based on your tires/pressure/track prep/clutch/suspension and a few other things.
-A lot of the fellas here are racers and therefore put a great of emphasis on reaction time. If you are out to have fun and E.T. chase then there's no need to do anything or buy anything to benefit reaction time.
Now on tires. As Dave T said the Hoosier 255 50 16's are great drag radials but are narrow.
They help with gearing(if necessary), hook great, roll great, and are good for some mid 1.3x's but mainly with an auto.
You can expect some 1.4x's with those tires with the right launch technique with a 6 speed vette like yours. I'm betting once you get the launch down that you'll cut low 1.5x's most regularly with a tire like that.
They will work well for you n/a with practice but will be a handful on the spray to launch especially on a track that is not well prepped. This would be my top pick for a drag radial if you were to run n/a a lot and occasionally nitrous progressively. If your planning on spraying all the time then we'll have to have a more in depth discussion. But keep in mind, if the tires are spinning you're not breaking and you have more fun when your car's in one piece. The 315 35 17's will likely hook similarly.
Surprisingly the shorter sidewall drag radials of today have been proven to get the job done on corvettes with big power. Again, much easier to hook for the auto but as Eric F. mentioned the balance/suspension of the corvette makes it possible.
So, you can go with a wide 17 or even 18 and get traction on the spray with a 26" tire.
You can also step it up to 27" or 28", but personally I would start with a 26" for many reasons, better left for another discussion.
As for slicks and your 6 speed, they will be the most consistent, and the best way to learn and dial in your set up with, especially the launch. You will need skinnies then.
I would start with the old proven, 'bread-n-butter' combo; 26x11.5x16 with skinnies up front. This tire combo will allow you to launch aggressively n/a and will work with the spray and allow you to go deep into the nines if the car has the gumption.
In summary, if you will go to the strip alot and want to really dial in the car and run with and without nitrous equally then I would get a drag pack with slicks (26x11.50x16 MT et streets) as my first set of tires. If your running n/a more so and nitrous occasionally and only want a drag radial then I would choose the Hoosier 255 50 16 and still go with a drag pack.
If you plan to run nitrous all the time and want the best et possible and don't car if you blow up stuff here and there then we'll add a bunch of other players to the mix.
Try and figure out realistically how and how often you'll be running this car as that will make the choice more clear.
Also don't forget about diameter and trap speed. Figure out what rpm you are comfortable going thru the traps at. Then figure around 132-134mph for 500+rwhp. Factor in rear diff. gearing and make sure it all makes sense. But this can be done after you have the car dialed in and that may take a set of tires.
M/T has a wider 16" available as well.
To clarify, the main duty of this car is chasing an great ET and of course the Saturday night grudge matches (midnight drags).
I'm really not interested in slicks, this car is not a trailer queen. I drive it to work on nice Fridays and cruise it on Friday night, so DR make the most sence to me.
That being said, I'm worried that the 255/50 is to narrow for s**tty track conditions. I'm leaning towards either the Hoosier 315/35/17 or the 315/30/18. I would consider the 16" setup but the performance (side wall) does not offset the weight in my opinion.
And I'd really like to stay under 27" diameter for gearing reasons. And I'm comfortable spinning this thing to 7100. And about the spray, once I get the progressive conroller dailed in I will only spray it when the "need" arises (grudge).
Basically, it will be cruised Saturday night then head out to the track for midnights. Which is heads up clock off (lots of gambling) grudge racing.
FYI, I put about 1200 miles on the car last year. So she doesn't see lots of time. Just the summer weekends.
Thanks a bunch guys for all the support here on the forum. You guys have saved me an immeasurable amout of time (trail and error) and money on wrong parts for my combo.
Thanks...Forgive me for any typos, my laptop is in the shop, I'm doing all of this from my phone.
I would make sure that the 16" rim won't limit you to a 26" tall tire. That would be worse than loosing side wall.
You need to have a minimum of a 28" tall tire on a Corvette and if you can squeeze it in, a 30" tall tire will hook WAY better and give you more gear for the big end.
keep these things in mind while you decide on a rim.
When you say you tried 18, 17 and 15 and had the best sucsess with the 15's. Was that all with the same combo ?? And if so what kind of HP are we talking ?? I know your way up there now but when you were playing around with 18's and 17's what were you putting down ??
Thanks..
