Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Temp question
Old Aug 15, 2011 | 06:17 PM
SouthBaySurfer's Avatar
SouthBaySurfer
Default Temp question
Haven't run at a dragstrip in 20 years...until two weeks ago. Took my bone-stock '08 coupe(A6, 2.73 gears) to Englishtown. Air temperature was 98, track was 171(according to my time slips), and the coolant temp was 220. Best run was 12.74 at 113.5. My question is: What should I expect under cooler conditions, say 60 or 65 degrees?
Old Aug 15, 2011 | 07:00 PM
paint it black vette's Avatar
you'll go faster 12.4's 117 to 118mnph my guesse. why not come out this sat 20 aug and run the cc challenge. do think the track temp on slip a bit high.
Old Aug 15, 2011 | 11:00 PM
LS1LT1's Avatar
LS1LT1
A stock C6 LS3 automatic has high 11 second/119mph potential in ideal air/track conditions so mid-low 12s are possible in 60-65 degree temps.
But it's not just the outside temps that hurt you, still got to keep that coolant temp down (which will obviously be easier in cooler air) regardless of outside temps.
Excellent idea!
To Temp question
