An automatic transmission is no more cheating in drag racing than a manual is on the oval or road course. It is simply the best equipment for the job at hand. Also, its not like most racers are simply putting their cars in drive and running through the gears, (Although I do, and I'm not apologizing for it either! My car runs its quickest et's shifting itself with my current setup, next year will be different.) Drivers are still having to watch their tachs and make shifts at the appropriate times to stay quick and consistant. I think its just as easy to be late or early on a shift with an auto as it is a manual, so yes driver skill still plays a role in winning races, and fellas THAT is the bottom line.
Hey, none of the "legends" out there in any form of motorsport are there because they did it the hard way. They got there because they won, mostly thru having the best setup to get the job done. Dragracing is IMHO 90% car, 10% driver. Autocross on the other hand is 90% driver, 10% car.
I disagree with this..... dragracing is a solid 80% driver, 20% car..... in particular bracket racing. For most of my races, I've been racing on a track that I cannot consistently hook on thus rendering my vette basically useless from a consistency point of view.... but somehow managed to win some rounds, whereas I have a buddy with the most consistent racecar I've ever seen, and he couldn't win back to back rounds if his life depended on it.
Its driver, regardless of the racing venue.
As far as if an auto is cheating.... thats just silly.
From: Los Angeles Founder, West Coast Corvette Challenge
Re: Automatic Tranny is Cheating? (Beach Bum)
Iam with Beach on his statement ."It's 80% driver and 20% car". Some of the comments almost refer to the auto car as being in a "autopilot" mode. :lol:
Keep in mind that alot of auto transmissions ,including my tranny have manual valve bodies. requiring the driver to manually shift through the gears.I have had both a 6M and a TH350 in this same car,so Iam talking from my own experieces.The driver is controlling the car in every aspect from:Dial in, heating the tires ,staging,engine temp,launch rpm,reaction time,shift points and finish line stategy.Cars do not win races....drivers do.
Phil
cheers,
Beach Bum
Beach, you hit the nail on the head....it's the driver and always has been. If you hang around local dragstrips long enough you will recognize the heavy hitters, those that consistently win year after year. Some of them own cars that look just plum scarry yet the heap often visits the winners circle.
Automatic transmissions far outnumber manually shifted cars throughout the country...just as they do at the dragstrips throughout the country. There are skilled stick shift drivers...there just aren't many stick shift cars.
Stick shift purists will love this....the NHRA 2001 Stock Eliminator Champion was Kevin Helms driving a very fast B/S 68' Camaro (4-speed). With the exception of a heads-up race (2 cars in the same class), Stock Eliminator cars dial a number just like we do at our bracket races. Kevin's advantage? I think it was skill. :yesnod:
Automatics definitely have an advantage in bracket racing, but it still takes some skill to race and win in an auto.
I agree!.....There is a skill to driving an automatic. If you just nail it at the tree you will just spin. Reading the track conditions and formulatying a good launch takes some practice.:D
Auto's are the way to go, just go to most bracket races and see who gets to the pay window. It will be a automatic car most of the time hands down. :yesnod:
You really need the ET streets or slicks to be consistent and win with the 6M. Unfortunately you start racing defensively because your afraid to break something. This approach effects your whole strategy to win.
Pro Stocks run a stick because the rules require it. Keep in mind that they are Liberty's, have a vertical gate shifter, and shift without a clutch. If you recall, two years ago they went back to a stick shift from air shifters to put some skill back into the driver.
When was the last time you saw a comp or super comp with anything other than a powerglide?
You are 100% on the money! Remember when Pro Stocks used Lenco's & Comps used Liberty. They said the Liberty wouldn't hold up to the Pro Stocks HP..
I forget who was the first Pro Stock to use a Liberty, but I remember he picked up .05 - .08 by going to a Liberty, & then ALL the PS were using Liberty's within a month..
I had markedly more success racing a six speed than I have since switching to an automatic. However the cost of replacing clutches was simply too high.
I run an automatic with a manual valve body. I have to shift the car myself or it will not change gears. However I have no clutch. For me it is the best of both worlds.
