WTB 17" Wheels that will fit over GS Big Brakes
Looking for a pair of rear wheels/tires (17") for strip. Must fit a C6 GS with big brakes.
NOT LOOKING ANYMORE....ALREADY PURCHASED A PAIR
1. Work with the stock fronts and...
2. Hook with 800 RWHP.
3. Have a diameter that will not set off AH/TC hell.
BIGMAC
"Big brakes" as in aftermarket? Or just big as in stock which are bigger than base C6 brakes?
OEM/factory C5 Z06 (17x9.5) front wheels will clear stock C6 Grand Sport (and C6 Z06) rear brakes. You can use either a 275-40-17 or 315-35-17 drag radial or even the Mickey Thompson ET Street bias ply 26-11.50-17 (probably better for manual cars) and get within acceptable range (but shorter) of the overall diameter/height of the stock 19" rims/tires.
Big Brakes
17's
Wheels for a drag pack
You right, where the hell do you find wheels that work on a GS/Z06? I thought I found a drag pack this morning, but the GTO spares will not fit a GS?Z6
Some guys go with 17x11 C4 ZR1 Reps. you have to get the -36 backspacing. These are a good option as you can get a set for around $450. Otherwise, you could go with some 17x11 WELD wheel but they are around $1000 and shipping takes weeks to months.
The biggest DR made for a 17" wheel is the M&H Racemasters and they are 325. I'm personally going to go with a set of 18x12 C6 Z06 reps to put on a 345 Mickey Thompson.
Best of luck
Best of luck
You could also look into some Cadillac CTS-V 18" spare wheels (with M&H or M/T 18" skinnies that are available), but even those might not clear stock GS/Z06 brakes without some other modifications.
Best of luck
Best of luck
Being that they are 11 inch wheels you need to run the -36mm offset. Here is a thread with pics of what i'm talking about.
https://www.corvetteforum.com/forums...-racing-2.html
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Wheels
I ended up buying a set of C4Z 17x11 SawBlades that fit over the GS rear calipers. Thinking of going with M&H Racemaster Radial Drag Race Tire 325/45-17.
tRACK
Any video of some runs?
MT Street Radials (slicks)
I have a pair of MT Street Radials size P275/40R17 for sale. Currently mounted on chorme wheels that fit a 2010 Dodge Challenger. They have about 12 runs on them. Looking for $300.00
Tire and Wheels
I have decided to go with C5z 17 x 9.5's with Hoosier 315/35/17's on the rear and see how they do. Got some good recommendations and help. Thanks to all
